Will this efficiently cool 7-8psi?
Old Aug 15, 2006 | 08:06 AM
xviper's Avatar
[QUOTE=JDM S2000,Aug 15 2006, 10:02 AM] http://cgi.ebay.com/ebaymotors/PWR-LIQUID-...sspagenameZWDVW
I found it on ebay.
it says it flows 390cfm
I would also like something like this for less turbo lag and a stealth look.
Old Aug 15, 2006 | 08:09 AM
xviper's Avatar
Originally Posted by Scorpion,Aug 15 2006, 10:03 AM
http://www.pwr-performance.com/intercooler.htm
Doesn't say much about it, but I've seen an RX-7 running 20+psi on a gt35r with one and the air temps where 40* over ambiant, which is pretty good.
For comparison, my Vortech typically runs 25*C over ambient.
Old Aug 15, 2006 | 08:10 AM
JDM S2000's Avatar
Banned
damn it i dont want a fmic.
why are these so expensive
Old Aug 15, 2006 | 08:16 AM
Sub-Zero's Avatar
Wow! That is great. I would also like to see some in and out temp results. Can you imagine out of the turbo into one of these mounted on the crossmember and curved utp to the intake. Does the water go through a radiator like the comptech does?
Old Aug 15, 2006 | 08:21 AM
xviper's Avatar
Their site does say it includes a "small" radiator, so it would be in the same sort of technique as the CT and VT systems.
Old Aug 15, 2006 | 08:29 AM
Scorpion's Avatar
I was speaking de english (fahrenheit)
Old Aug 15, 2006 | 08:32 AM
Scorpion's Avatar
In all actuallity these units are identical to the aftercoolers supplied with the SC. The main differance is that there are no bends, and it's not a square inside like the aftercoolers. This "should" make them more efficant from a flow point of view.
Old Aug 15, 2006 | 08:40 AM
stphotographer's Avatar
This is getting interesting, but gets expensive fast.
From this old thread it appears that the Comptech flows about 850 cfm and the Vortech about 1000 cfm.
https://www.s2ki.com/forums/index.php?showt...0&#entry6542836
Old Aug 15, 2006 | 10:49 AM
Scorpion's Avatar
Those numbers are more than likely lab numbers. A NA S2000 uses around 315 cfm (depends on %VE at 9000rpm). At 8psi you are looking at around 500 cfm.
VAF = (CI/1728) x (RPM/2) x VE
Old Aug 15, 2006 | 12:11 PM
JDM S2000's Avatar
Banned
ill probably just stick with a fmic, it will cost like 10 times less.
