Windshield washer hose melting
Old Apr 11, 2015 | 05:21 AM
cmn's Avatar
cmn
Default Windshield washer hose melting
I have a problem with my washers hose melting from the heat of the manifold, even though I have protected it with heat protective sleeve like this.
What do you other guys use? Is there other better sleeves that could work? Or will a braided stainless steel hose work better inside the sleeve? Thankful for tips!
Old Apr 14, 2015 | 07:19 AM
cmn's Avatar
cmn
Am I really the only one with this problem?...
Old Apr 14, 2015 | 08:30 AM
KaNgArOo's Avatar
Is your manifold heat wrapped? and are you using a turbo blanket?
Old Apr 14, 2015 | 11:35 AM
cmn's Avatar
cmn
My manifold is not wrapped, but it's ceramic coated. I also use a turbo blanket.
Old Apr 14, 2015 | 01:16 PM
herecomesboost's Avatar
Interesting. Never had this issue. Some form of wrap/sleeve is probably your best bet.
EDIT: didn't read that you are STILL melting them with sleeves. I'd switch to a hose with a higher temperature rating (same ID) and reuse the sleeves.
Old Apr 14, 2015 | 01:28 PM
blixhavn's Avatar
I removed my windshield washer bottle/hoses... I just make sure I have a bottle of water under my seat if I'm driving on a crappy day and put my arm out the window and spray the windshield... seriously
Old Apr 14, 2015 | 09:52 PM
Mnstr2000's Avatar
Silicone tubing instead of vinyl, at least 250 degrees better
Old Apr 15, 2015 | 06:41 AM
vader1's Avatar
Lava Mat.
Old Apr 15, 2015 | 07:29 AM
CoolGuy094's Avatar
LOL, that is awesome!!!
Old Apr 15, 2015 | 08:38 AM
blixhavn's Avatar
It works, but I never drive the car when it rains anyways so I never need it
