Yet another walbro fuel pump thread
Old Jun 10, 2010 | 03:09 AM
  #21
freshs2k's Avatar
I was at stock fuel pressure and only ran 18 psi and it failed I'm on my second walboro and the first one sounded terrible. My car shut off after cruising on the highway and stop and go traffic only 35 miles of driving from my shop to my house. I drive my car a lot the last thing I want to worry about is the pump.
Old Jun 10, 2010 | 04:14 AM
  #22
s2kswe's Avatar
Okay, so a slightly OT question then...
What do I have to think about when doing a pumphanger? I am thinking a feedconnection, a returnconnection, a holder for the pump and the fuel level sensor.
Smart cable solution thorough the upper "disc" to allow relay rewired pump. As i have rebuilt my system to a returnsystem i do not need and releasevalve on the hanger like my stock hanger does?
Anything else needed? I am just gonna fabricate one.
Old Jun 10, 2010 | 05:06 AM
  #23
siadam's Avatar
I've used several Walbro's on different setups and never had an issue.
I usually purchase them from a known source, instead of eBaying it up..and that has treated me well.
For the price, they can't be beat.
Old Jun 10, 2010 | 05:10 AM
  #24
wadzii's Avatar
Banned
I have used alot of walbro pumps and had a few fail, but never in this way.
are you sure there isnt a problem with your fuel pressure regulator or your wiring?
even if the resistance of the pump increases it should draw more current as a result and the voltage should remain the same.
o2 feedback is nearly useless at WOT
Old Jun 10, 2010 | 05:35 AM
  #25
Spec_Ops2087's Avatar
Base fuel pressure is about ~340 KPa (or about 49psi) and my max boost is 150 Kpa (or 21psi) so max pressure is about 70psi (I'm using the stock FPR so it's a 1:1 rising rate).
My fuel pump came from inlinepro both times, I doubt it's a fake.
I rewired my fuel pump to 10ga wire with a 30A fuse iirc. Wiring should be perfectly fine.
How would I know if my FPR is going bad? As I said, everything is fine until driving for a bit (or it's hot out) and the pump gets loud while also dropping fuel pressure slowly but surely.
Old Jun 10, 2010 | 08:34 AM
  #26
I should mention, that my base fuel pressure is with the vacuum line connected so without it connected it should be 8-10psi greater? Is there a problem here?
I have been hearing a hissing noise coming from my engine near the fuel rail. I think it's the PCV valve starting to leak a bit (should probably order a new one) but now I'm thinking maybe it's my FPR?
Ugh, time to be paranoid again.
Old Jun 10, 2010 | 08:37 AM
  #27
TRBOKEV's Avatar
I had a problem with my first fuel dampner... There is a screw inside of it and it somehow stripped and came loose.. I have no idea how this happened but caught it when I was swapping rails and heard something loose inside of it.
Old Jun 10, 2010 | 08:42 AM
  #28
TRBOKEV's Avatar
Theres also a screen/filter in the rail under the FPR you may want to check.. I doubt it's the problem though. Don't damage it though, they don't sell the filter seperate from the damn rail. ( ask me how I know).
Old Jun 10, 2010 | 08:53 AM
  #29
I'll double check my fuel rail / FPR when I get home just to be sure nothing is wrong with it
Old Jun 10, 2010 | 01:10 PM
  #30
Well my static pressure is about 56psi. Does this seem right?
I squeezed the line coming from my oem FPR and the fuel pressure increased as it should. I can't see my FPR being bad...
