Zero Clearance
Old Feb 13, 2007 | 02:27 AM
Sideways's Avatar
Default Zero Clearance
Very impressive results from working with zero clearance. Spool up is very quick.
Check it out:
http://www.6speedonline.com/forums/showthr...light=clearance
Old Feb 13, 2007 | 03:26 AM
C45P312's Avatar
Just wow. That guy has a dicipline of a ninja. This would be cool to try if someone had a spare turbo.
Old Feb 13, 2007 | 06:30 AM
Vapor's Avatar
You have to have that sort of control when breaking those in.
The blades actually cut themselves on the wall as they heat up so that they're a perfect fit at temperature. You have to bring them up to heat slowly, because you want a gradual shaving, not bending and shearing. Skip any steps or try and rush it and you'll end up with a poorly performing unit or worst case an expensive paper weight.
we used a unit of that design for a project here at work for a marine application.
Sadly, I tried to get them to order me one as well, but they poo-poo'd the idea.
Old Feb 15, 2007 | 09:42 AM
Sub-Zero's Avatar
I wonder what he used to coat the housing? Jet coat/high temp ceramic coating?
Old Feb 15, 2007 | 10:58 AM
RacerXI's Avatar
I didn't notice where he called out the coating, but you can coat the turbo housing with a high temp coating (jet hot, swain-tech, insert your coater of choice here).
Old Feb 15, 2007 | 05:32 PM
Tyraid2K's Avatar
i can't find this product anywhere on the internet, im interested though
mrclox
May 1, 2006 07:44 AM
wang_uk
Jan 22, 2006 10:56 AM
AusS2000
Jul 13, 2005 01:17 PM
1Randyc
Oct 11, 2001 07:24 AM
