Got Vtec?
Old Oct 18, 2001 | 05:05 PM
4IGS2000's Avatar
Spammer
Default Got Vtec?
APEXi VTEC Controller
Old Oct 18, 2001 | 06:28 PM
umvue's Avatar
What is the advantage/disadvantage of setting VTEC point earlier/later? You got any dyno chart to show??
Thanks
Old Oct 18, 2001 | 06:39 PM
jcasta02's Avatar
What the hell is that?
What does it do?
Old Oct 18, 2001 | 06:47 PM
4IGS2000's Avatar
Spammer
What does it do?
Its 10-12 HP on the DYNO thats what it is!
Old Oct 19, 2001 | 05:49 AM
espentan's Avatar
How can a VTEC-controller give more hp?
It only changes the on set point for the high cams, doesn't it?
I've yet to hear of any hp improvments by changing the set point.
Old Oct 19, 2001 | 06:57 AM
Wesmaster's Avatar
A V-AFC controller does two things.
Old Oct 19, 2001 | 08:48 AM
Fed's Avatar
Fed
How much do one of those run? What is involved in installing it?
Old Oct 19, 2001 | 09:08 AM
Wesmaster's Avatar
Cheapest I've seen online is $300, and up to $450. Don't pay over $350.
The problem with installing is that there is no harness for the S2000. If you decide to install it it will all be spliced, or you'll have to make a custom harness.
Old Oct 19, 2001 | 10:14 AM
Fed's Avatar
Fed
What does it tie into, does it piggy back on the ECU? I imagine once it is installed you must tune it through a series of dyno tests to get the best fuel/air mixture? (Sorry about all the questions, kinda new at all these things).
Old Oct 19, 2001 | 10:32 AM
Wesmaster's Avatar
Yes, and Yes. I know that others here have experience with them, and may be able to go into greater detail.
