Holy Moly
Old Feb 9, 2003 | 04:47 AM
sehenkel's Avatar
Awesome, simply awesome..................
Sign me up for one of these!
Dodge Tomahawk Concept Motorcycle
The Dodge Tomahawk can reach 60 miles an hour in about 2.5 seconds, and has a theoretical top speed of nearly 400 mph. Each pair of wheels is separated by a few inches and each wheel has an independent suspension. Bernhard said four wheels were necessary to handle the power from the engine.
- 500 bhp (372 kW) @ 5600 rpm (60.4 bhp/liter); 525 lb.-ft. (712 Nm) @ 4200 rpm
- 10-cylinder 90-degree V-type, liquid-cooled, 505 cubic inches (8277 cc)
- 356-T6 aluminum alloy block with cast-iron liners, aluminum alloy cylinder heads
- Bore x Stroke: 4.03 inches x 3.96 inches (102.4 x 100.6)
- Two pushrod-actuated overhead valves per cylinder with roller-type hydraulic lifters
- Sequential, multi-port electronic fuel injection with individual runners
- Compression Ratio: 9.6:1
- Max Engine Speed: 6000 rpm
- Fuel Requirement: Unleaded premium, 93 octane (R+M/2)
- Oil System: Dry Sump; takes 8 qts. Mobil1 10W30 Synthetic
- Cooling System: Twin aluminum radiators mounted atop engine intake manifolds, force-fed from front mounted, belt-driven turbine fan. Takes 11 quarts of antifreeze.
- Exhaust System: Equal-length tubular stainless steel headers with dual collectors and central rear outlets
Old Feb 9, 2003 | 04:59 AM
Legal Bill's Avatar
I saw a film clip of it on Speed Chanel. It was very "porpoisey", kinda rolling up and down on its suspension as the test driver accelerated.
Old Feb 9, 2003 | 09:05 AM
AquilaEagle's Avatar
Administrator
LOL thats mad
Old Feb 9, 2003 | 11:08 AM
blackguy's Avatar
thats nice andall but has ayone seen the honda rune bike? it's no tomahawk, but it redefines that harley look.
Old Feb 9, 2003 | 12:25 PM
pierceman's Avatar
insta-death on that thing, crazy
Old Feb 9, 2003 | 05:50 PM
Mrsideways's Avatar
Is it called tomahawk because it's named after the cruise missle?
Old Feb 9, 2003 | 06:00 PM
jmrobins's Avatar
Ummm, how exactly do you turn? I mean, normally you lean slightly the opposite direction and the bike lays down and you turn the correct way... with the two tires...leaning... how? some weird suspension that keeps the other tire touching when you lean? It sounds like an insane machine built to make a point, but seriously - why would you ever even wanna touch it? YIKES!
Old Feb 9, 2003 | 06:01 PM
greeny488's Avatar
actually the theoretical top speed is 300 mph not 400
Old Feb 9, 2003 | 06:38 PM
nine grand's Avatar
Meh, I'd take a GSX-R600 any day. interesting though.
Old Feb 9, 2003 | 06:44 PM
airgate's Avatar
LMFAO! I'm sure the folks at Daimler-Chrysler will patent that phrase - "insta-death" right away!
