New Cyberdyne Digital Gauges!
Old 12-11-2005, 05:02 PM
GSU S2000's Avatar
Default New Cyberdyne Digital Gauges!
monday last week I went to ST-Performance in savannah georgia to get my gauge cluster and oil press / temp gauges installed. The install took about two hours and it was a great experience, they got me out on time, in on time, and did a extremely clean job on the install. They even hooked the guages up to the dimmer function (the gauges are not designed to do this) but they dim and brighten with my factory panel. Here are a few pics of my setup for everyone, and if anyone needs to ask I have no complaint on their work and would not mind having more stuff done there either.
the only reason they look red is because of the flash of the camera, to the eye they look black like defi(sp?) gauges
Old 12-11-2005, 05:08 PM
LubedKoala's Avatar
I don't see the pics..
Old 12-11-2005, 05:12 PM
4doorj's Avatar
i like them!!
GSU S2000's Avatar
thats strange, I can see them fine, try reloading them?!?!
Old 12-11-2005, 05:31 PM
XclusiveAutosports's Avatar
They look good ... between the name and the style of the gauges it reminds me of the terminator
Old 12-11-2005, 05:42 PM
Ravenwerk's Avatar
Looks good. Definitely a slick mod.
What's the highest oil pressure reading you've had?
Old 12-11-2005, 05:44 PM
LubedKoala's Avatar
That is weird. I've noticed this before. There's not even an image place hold. It just looks like there were never pics there. Obviously its something with my browser.
Old 12-11-2005, 05:45 PM
GSU S2000's Avatar
80... the gauges dont read to what the oil pump can put out, but if I get a reading under load then I know to pull off the road and turn the car off asap.
Old 12-11-2005, 05:48 PM
gary_phd's Avatar
for Cyberdyne! Have the boost/vacuum with memory (bottm gauge). Btw, all Cyberdyne has a dimming feature I believe (i.e., dim when lights turn on). I had applied a 30% tint to the gauge since the LED was WAY brighter than the console. Now brightness matches almost perfectly!
My top gauge is a Summit Racing oil pressure gauge (100psi). I didn't go with Cyberdyne becaue it only goes to 80psi max. Our cars can see > 85 psi - 90 psi. The guages matched pretty nicely,
Old 12-11-2005, 05:55 PM
gary_phd's Avatar
Forgot to ask, how did they install the pressure and temp sender? Did they use an oil adapter plate? (e.g., Greddy adapter). If so, is the oil sender directly on the plate? Thanks!
Quick Reply: New Cyberdyne Digital Gauges!
