S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
2006 passenger seat removal help
Old Sep 1, 2013 | 02:10 PM
HogBeast's Avatar
Default 2006 passenger seat removal help
I tried to remove my passenger seat and hit a snag with the sensor box on the rails. There are two wire connections from the floor into the seat. One connects to the seatbelt sensor which I was able to disconnect but the other connects to the SRS weight sensor box. It's kind of a tight fit under there and I can't pull out that connection by hand. Is there some special tool I need to undo that connection? has anyone else ran into the same issue?
Old Sep 1, 2013 | 03:47 PM
99SH's Avatar
There are 3 connectors to the passenger seat sensor electronic box. The plug you need to remove is the one closest to the passenger door. Just like any other harness, press on the middle and slide the plug out. If you need more room, unbolt the 4 fasteners holding the rail to the floor-board and tilt the seat.
jst2878
Jan 24, 2016 06:09 PM
gptoyz
May 17, 2014 07:37 PM
JeffEk
Aug 11, 2013 01:29 AM
S2PIDSTYLE
15
Mar 6, 2008 07:10 AM
