S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Adhesive Residue - Dashboard
Old Apr 1, 2011 | 06:10 AM
realmike15's Avatar
Default Adhesive Residue - Dashboard
Need to remove adhesive residue from the dashboard, not sure what was there probably some sort of compass or other tacky device. I was going to try Goo Gone but didn't know if that was safe for the dash. Any suggestions on how to safely remove something like this?
Old Apr 1, 2011 | 11:14 AM
termigni's Avatar
Goo Gone or may be Windex?
Old Apr 1, 2011 | 12:00 PM
dwight's Avatar
Rubbing alcohol usually works fairly well and is likely already on hand.
Old Apr 2, 2011 | 03:52 PM
midnightmethane's Avatar
GooGone will take care of it for ya....some of the best stuff that you should always have on hand
Old Apr 3, 2011 | 08:12 AM
croftoncustoms's Avatar
NAPA adhesive remover!
So prodectus WILL fade/bleach/ bubble/ destroy the material and then your dash will be realllly bad
Old Apr 3, 2011 | 12:29 PM
rioyellows2k's Avatar
I'd say regular goo gone since it's not chemical solvent based. Maybe set your car out in the sun so the dash gets nice and hot/warm and just get busy with citrus based goo gone and some elbow grease.
Old Apr 4, 2011 | 05:00 AM
realmike15's Avatar
Thanks guys. I'll try goo gone first, since I have some at home.
Old Apr 5, 2011 | 05:34 PM
dwight's Avatar
How is Goo Gone not chemical solvent based?
http://www.magicamerican.com/media/1...goo%20gone.pdf
Old Apr 10, 2011 | 03:53 PM
It's not the same chemical solvent as say "3M Adhesive remover" or similar. MSDS sheet. Cute.
Old Apr 15, 2011 | 09:40 PM
dwight's Avatar
It's petroleum distillate based. I don't see how it isn't a chemical solvent. I doubt that dichloromethane, benzene, toluene, etc are the same as say "3M Adhesive remover", but they're still solvents. Water is a chemical solvent too.
