S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
AP2 red door panel swap
Old May 3, 2013 | 01:36 PM
dv55xc's Avatar
Default AP2 red door panel swap
right now my 07 NFR has all black interior. i want to swap out just this panel with the red insert: Name:  redpanelinsert.jpg
do we have to swap out the whole door panel or can that red piece be swapped out?
Old May 3, 2013 | 02:02 PM
nadeem's Avatar
the red piece can be swapped out. remove the door panel, then there are about 11 screws on the backside that separate the red part. shouldnt take longer then 15 min for the whole thing.
Old May 3, 2013 | 02:04 PM
nadeem's Avatar
Yes, you can swap out just the red part. Remove the door panel, then there are about 11 screws on the backside that separate the red part. Shouldnt take longer then 15 min for the whole thing.
Old May 4, 2013 | 12:19 AM
dv55xc's Avatar
would there be a part number of that per chance?
Old May 4, 2013 | 12:57 AM
nadeem's Avatar
i do not know. you can take the center and get it upholstered at an interior shop tho
Old May 4, 2013 | 08:03 AM
dv55xc's Avatar
thats an option. i found a guy whos parting out an ap1 that has that door panel. i wonder if its compatible with the ap2 door panel.
Old May 9, 2013 | 07:07 PM
HDS-S2K's Avatar
they do fit is the same thing just that ap2 panel has tweeters and the net bag other than that they are the same
Old Jun 5, 2013 | 08:11 PM
Aturner87's Avatar
Are you still working on swapping the door panels?
Old Jun 6, 2013 | 06:37 PM
zeroptzero's Avatar
I sent my oem black panel inserts to JPM Coachworks and they re-upholstered them in high quality leather to the colour of my choice. I'd recommend that if you want a better quality insert and you can pick any colour leather and stitching combo that you want. You can even select the ap1 vs ap2 pattern if you like as they are different ( I went with the ap1 insert pattern on the ap2 door cards as I prefer the Ap1 pattern) . I love my new inserts and JPM Coachworks has great products.
Old Oct 16, 2014 | 03:11 PM
Semp's Avatar
Does anybody know the part number of these inserts?
s2jerris
Mar 6, 2012 11:31 AM
blueducatikidd
Nov 11, 2010 01:15 PM
getmadboy
Mar 5, 2010 01:30 PM
youngjae
Dec 12, 2009 11:03 AM
nj2tn
Jun 6, 2006 04:19 PM
