S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Center console insulation on ap1
Old Apr 26, 2020 | 07:47 AM
happ's Avatar
Default Center console insulation on ap1
I've noticed my drive terrain is loud so I decided to dig in. The car has been swapped and worked on by others before I got it. I removed the console and noticed no insulation under it. I can see small old pieces of foam there so I assume it had some at one point. Is that correct? I can't find pics of it online.
Anyone ever added some in here or know where I can get some oem one?
Attached a pic, any help would be appreciated!
Old Apr 26, 2020 | 11:33 AM
DutchyFutch's Avatar
There's no insulation in there from stock.
Old Apr 26, 2020 | 03:59 PM
dwb993's Avatar
DutchyFutch is correct in that there is no insulation near the e-brake.
However, there is a thick foam insulator around the gear shift area that appears to be missing in your pictures. It is listed in the parts catalog as "Insulator, Change Lever", Part #74699-S2A-000 (about $20). When that foam disintegrates, it turns into a mess. Clean as much out as you can with a vacuum and install a new piece. I did mine a short time ago.
Old Apr 27, 2020 | 08:41 AM
happ's Avatar
Thanks!
Thanks alot for that man I'll look it up! Did you notice any change in noise by doing so?
Old Apr 27, 2020 | 10:21 AM
dwb993's Avatar
Not really, but I don't have much wheel time this year, either. I just did it when I took it out of storage, but its back in storage now!
Old May 23, 2020 | 12:28 PM
jwfisher's Avatar
Just opened up our 2003 GPW two hours ago for the first time ever to put on an AP2 console (a very worthwhile mod: no cutting, easily reversable).
There is some foam around the shifter base itself... the area under the cup holder is wide open - no insulation. But there is a piece of tape you are missing ;-)
And the metal is kind of crapped up... maybe a leaky water bottle?
You have a crImped wire MOON YOURS... that's not good!
Ajval79
Feb 23, 2019 12:52 PM
MrFunk
Feb 5, 2019 01:18 PM
Anualmix
Nov 2, 2017 02:24 PM
skidisk
Oct 31, 2017 05:47 AM
ducatista
Cars for Sale
Sep 4, 2016 10:00 PM
