S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
How to remove center console carpet?
Old Mar 20, 2007 | 06:33 AM
billo's Avatar
Dan,
It's been a long time, but I think I pulled the radio door aft thereby unsnapping the lower attach points on the facia surrounding the door. It takes a bit of force as I recall. I know there are instructions for popping that piece somewhere on this site. Once the bottom of the radio trim is loose, the cover should go in more easily. As you mentioned earlier, it is meant to replace the carpet, not go over it.
Old Mar 20, 2007 | 06:38 AM
billo's Avatar
Okay, with apologies to Rick in advance...Go to Ricks Signature accessories, click on installation instructions and look at step 7.
Old Mar 20, 2007 | 01:33 PM
billo's Avatar
On the way home from work I looked at my installation. Seems like I must have removed the small triangular panels from each side to facilitate installation.
Old Mar 20, 2007 | 01:39 PM
Dan H's Avatar
Thanks, I still can't get it under the dash thing (even with radio cover and triangular pieces removed.) So I might have to cut it right before the dash. The radio cover should cover it all up but I'm going to keep trying to force it under the dash.
Old Mar 20, 2007 | 01:45 PM
billo's Avatar
let me go down stairs and try to see where I cut mine,
Old Mar 20, 2007 | 01:52 PM
billo's Avatar
Okay, looks like I cut mine about even with the screw on the triangular piece. Dan, I remember cutting the cover a few times, slowly shortening it until it fit. I have about 1 inch under the radio, maybe slightly less.
Old Aug 30, 2007 | 12:07 PM
DeadLock23's Avatar
Anyone else have some tips, I am in the process of adding the OEM center surround where the carpet used to be.
I can't get the carpet out, where should I cut, any pics?
Old Feb 7, 2015 | 12:59 PM
beaudin223's Avatar
i just bought 06 center console in leater , im looking to take off my carpet but on riks DIY they just show how to put them on the oem carpet but i think for the oem one i need to take off the old one , my main question is how i get the old carpet from under the radio , any other DIY or somebody can help me with this ?
Old Feb 8, 2015 | 03:47 PM
beaudin223's Avatar
any one ?
Old Feb 9, 2015 | 05:47 AM
Moddiction's Avatar
Former Sponsor
Cut it or remove the stereo and pull carpet out.
