Pretty sure there's a spring clip which should allow the cover to pop off once the screw is removed.
I cracked mine several years ago, glued it together, and put it back in the car. Bought a replacement which is still sealed in the Honda bag -- don't notice the repair and never got around to replacing the part.
Hi Chuck. Thank you kindly! The images helped. The one screw holds it in place, as well as 2 clips. Once I saw in the photos where the clips were (behind the item) it made it easy to know where to pry...and voila, it came out easy as pie.
