Mystery trim clips
I took the pillar and rollbar garnishes, rear tray, and trunk carpets apart months ago. I'm finally putting it back together, and I have a few trim clips left that I only vaguely remember. Anyone ID them?
I am going to guess pillars because I did my top and that was nothing like that in my truck or rear tray.
the 2 on the right are used by the trim pieces that run from the rear of the doorjam, to behind the seat. Or..the front doorjam pieces also each use one. Or, there are also 4 that hold the rear tray.
The first one looks like the wirehold, which you will find behind the above-mentioned rear-of-doorjam panel, on the passenger side. If I recall correctly, it holds either the convertible-top motor wiring, or the door switch wiring. My AP1 didn't have a matching clip on the driver's side.
