S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
OEM-look LED cluster replacement bulbs?
Old Oct 30, 2020 | 06:03 AM
JohnEBlaze's Avatar
Default OEM-look LED cluster replacement bulbs?
As the title states I'm looking at swapping out the bulbs for the cluster, a/c, and radio controls to LED. I've looked through all of the threads seeing lot's of LED swaps but I haven't seen something that retains the look of the OEM lights. Is there a company that offers this?
Old Nov 1, 2020 | 05:26 AM
Kyle's Avatar
The closest you will get to an OEM-look is the QUBE cluster from https://qube-engineering.com/
Pretty involved if you DIY, or you can send yours in for an exchange.
As far as a PnP bulb to retain the OEM look, there is not. I experimented with many styles of different LEDs in the cluster and unfortunately they all hot-spot. I tried every wide-angle LED I could find for the cluster, frosted lenses, etc etc. None produced the same glow as the incandescent bulb. LEDs are too harsh and too directional. The OEM cluster uses a white reflector behind the LCD screen & color filter to illuminate everything uniformly. As I said above, only the QUBE cluster can replicate this effect because it uses a full-array LED board vs just a couple of bulbs.
Here's the results I got when I attempted this while using LED bulbs.
Old Nov 2, 2020 | 01:59 PM
TheBasedDoge's Avatar
LED bulbs are not gonna work, as the above posted pointed out.
I was able to make my own LED backlit cluster without paying for the Qube. I had to cut out the difuser panel out of clear acrylic, and line the inside of the cluster with a pure white LED strip for even lighting.
I didn't really take any pictures during, but my friend wants to do this on his car so i'll take pics and write up a DIY when we do that.
result:
Old Nov 5, 2020 | 11:54 AM
JohnEBlaze's Avatar
result:
Thanks for the response. I think I'll go Qube. The install doesn't look to difficult which is nice.
Old Nov 6, 2020 | 04:06 AM
Chuck S's Avatar
QUBE will install the panel for $50 but you gotta send yours to them or make a $500 deposit and pay a $75 core charge.
This is what the S2000 dash should have looked like.
-- Chuck
spyder2000
Jul 1, 2016 08:55 PM
dlq04
Jun 29, 2016 01:17 PM
