S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
rear defroster sub wire harness window support
Old Jun 26, 2014 | 04:27 PM
kurtlmt's Avatar
Default rear defroster sub wire harness window support
I am putting on a new after market top. I have not been able to remove the old defroster sub-wire harness from the old top because I can't get the plastic box wire support that holds the wire harness in place between the two window connections. I ordered a new harness and then found that I need to get that little plastic support box because the harness does not come with it. I ordered what I thought was the box but turns out that it is just the cover for the bottom part that is apparently only on the window which is available by buying the whole soft top. This is Honda genius at it's best.
Have any of you guys had to deal with this? And what do you use in place of the stock support box. I would supply a picture if I could figure out how to upload it.
AZS2KDancer
Arizona Classifieds
Jun 19, 2015 04:50 PM
AZS2KDancer
Jun 11, 2015 06:13 PM
Soul Coughing
Nov 10, 2013 03:35 PM
Suzuka_Joe
Jul 20, 2011 03:28 AM
stocky
Jul 20, 2010 08:30 AM
