S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Securing Ricks S2000 windscreen
Old Oct 2, 2012 | 12:46 PM
RoninS2k's Avatar
Default Securing Ricks S2000 windscreen
He guys,
I bought the Ricks full tinted windscreen and I have been securing it with napkins or folded electricla tape.
It works great until i need to open the console or it gets loose.
How have you guys fixed the wind buffering problem?
TiA
Old Oct 2, 2012 | 01:55 PM
Manga_Spawn's Avatar
Site Moderator
I used a TON of clear silicone to keep my Js2k one from rattling.
Old Oct 2, 2012 | 05:50 PM
RoninS2k's Avatar
Wouldn't that be permanent?
Old Oct 3, 2012 | 11:11 AM
Site Moderator
What? The bigger I bought I had to take apart the oem one and just replace the clear plastic part. Thats what I had to use the silicone on. The base I just used the oem screws.
Old Oct 3, 2012 | 11:50 AM
JackTs2K's Avatar
Veteran: Army
I think he means to say that the windscreen vibrates in the windstream. I had one of these on the MY2000 and they sold a bumper kit that mounted on the roll bar hoops to supposedly fix that problem. The website still shows an installation .pdf for the "improved" vibration damper that looks like some kind of wedge.
Old Oct 4, 2012 | 05:26 AM
Moddiction's Avatar
Former Sponsor
Just use some clear silicone as mentioned above. It will fill the void between the new windscreen and the base it bolts into. That will prevent it from wobbling/squeeking in the wind.
Old Oct 13, 2012 | 08:19 AM
TODDS 2000's Avatar
Originally Posted by RoninS2k
He guys,
TiA
What i did was i drilled two small holes in the side of the roll bars, i inserted a roll pin in each and the covered them with a small black hose cap.they stick out just enough to touch the windscreen.they do not interfere with the operation of the windscreen. i positioned the roll pins so the windscreen stands straight up and down. only downfall is when backing up in the dark the reflection in the screen makes it a challenge sometimes.
Old Nov 3, 2012 | 12:16 PM
RoninS2k's Avatar
Originally Posted by TODDS 2000
Originally Posted by RoninS2k' timestamp='1349210815' post='22053738
He guys,
TiA
Thats a good idea!!
JS2k.com
20
Apr 20, 2018 01:07 PM
hylysly
Jun 14, 2006 11:21 AM
atxs2kboi
Oct 15, 2005 06:06 PM
bw993
Oct 13, 2004 05:04 PM
Formula
Feb 9, 2004 05:29 PM
