S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Show me you phone mounts!
Old Apr 19, 2012 | 06:29 PM
Thatg's Avatar
Default Show me you phone mounts!
Looking for ideas. Something easier to remove or hide is what I'm really after. I was thinking about this floor mount because it would be easier to stow under the seat but I wonder how it'd look in the s2k. Post pics of your mounts here!!
http://www.walmart.com/ip/Arkon-SM48...ndingMethod=rr
So here's what I came up with. Perfect placement but it does wiggle a bit on bumps
Old Apr 19, 2012 | 07:01 PM
Thatg's Avatar
Would be cool to fit this to the modifry bracket. But wouldn't be as easy to stow away
http://www.walmart.com/ip/Arkon-1-Ad...older/15258093
Old Apr 19, 2012 | 07:30 PM
jrs21c's Avatar
Here's how I am doing it!
Old Apr 19, 2012 | 08:15 PM
Mooseman's Avatar
I too have the modifry dash bracket but I do not have a phone mount. Instead I use this product:
http://www.amazon.com/Scotch-Heavy-D...4894936&sr=8-2
So the product is exactly like velcro, but much stronger and it doesn't lose it's adhesion to each other. The strips that are attached to each other are the same, but they can snap into each other, whereas velcro is two different strips (the loop and hook).
What I did is bought a case for my phone, cut the strip in half as you don't need so much, pasted one on the back of my phone and one on the modifry bracket. I have two cases depending on whether I'm driving or not and it not a hassle switching cases at all. When I get in the car, it only takes a second to snap my phone on the bracket and easily switching from landscape or portrait view.
Don't have any pictures on me, but this should be pretty clear.
Old Apr 19, 2012 | 08:21 PM
Thatg's Avatar
i like this! does it swivel? is it easily detachable or is it screwed into the bracket?
Old Apr 19, 2012 | 08:36 PM
Thatg's Avatar
does anyone have something like this, p.s. i like how he bitch slaps the dummy phone around
http://www.youtube.com/watch?v=VFTzMTOTecU
Old Apr 19, 2012 | 08:50 PM
jrs21c's Avatar
I drilled a hole or two on the bracket and attached it with a set of small washer, bolt and nut. Then it was making some noise, so I put some electric tape on the washer. Yes it swivel just a bit, but only because the hole I drilled was a bit bigger than the diameter of the bolt.
I've had it for a while, and it is working fine for me.
Old Apr 19, 2012 | 08:58 PM
Thatg's Avatar
well i just ended up buying the one i posted the video to from walmart, ill post some pics and a review of it when i get it. my big concern is how its going to hold on the dash
Old Apr 20, 2012 | 04:13 AM
takeshi's Avatar
Don't overlook the electronics subforum as this is a fairly common topic in there. I always highly recommend the Modifry dash bracket (not the Panavise which Modifry also sells) + ProClip device mount.
https://www.s2ki.com/s2000/topic/829...t__p__19819243
Old Apr 20, 2012 | 07:28 AM
Drkphnx's Avatar
I made this and put it in the air vent on the right by the AC controls. Works great and didn't cost me anything since I used work supplies lol.
http://www.instructables.com/id/Bind...one-Car-Mount/
