S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Soft Top Wind Noise
Old Aug 11, 2014 | 03:44 PM
JulioOchoa23's Avatar
Default Soft Top Wind Noise
So I was wondering if any of you guys have the same problem that I do.
So when i'm driving, it seems wind seems to seep in from the top of the soft top.
Its not that noticeable until I hit above 65mph+
The only way it goes away is if I pull it down and hold it from the little grabbing thing right in the middle.
If I let go, it just comes back.
Do you guy have this problem?
Any fixes?
Thanks in advanced.
Old Aug 11, 2014 | 07:09 PM
jcianfrani's Avatar
Tightening your latches should do it. Happened to my friend's S.
Old Aug 21, 2014 | 02:44 PM
all the screws on it are super tight, i dont know what else i can do
Old Aug 22, 2014 | 01:34 PM
croftoncustoms's Avatar
Put a spacer under the catchers which will then make the latches pull the top down lower creating a tighter seal
Old Aug 30, 2014 | 05:26 AM
Fokker's Avatar
http://gladfab.myshopify.com/product...d-top-shim-kit
Easy to install.
Old Sep 16, 2014 | 08:14 AM
solitarycheese's Avatar
Either that or hard top strikers. Before buying any new parts try cleaning the seal on the lip of the roof with a wet rag (or windex if its really dirty) and lubricate it with Shin-Etsu grease.
Old Nov 2, 2014 | 04:47 AM
danno1400i's Avatar
Any fixes?
Thanks in advanced.
Old Nov 2, 2014 | 04:53 AM
danno1400i's Avatar
I used a small piece of clear plastic tubing over each latch. you can get the tubing a any home depot, and cut a small piece just long enough to fit. it pulls the latch down just enough to stop the wind noise.
Himura357
Mar 28, 2018 10:51 AM
Talent
Oct 20, 2014 01:31 PM
DJT
Nov 22, 2011 03:11 AM
SLstone s2k kid
Nov 8, 2006 08:00 PM
