S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Tinting Wind Visor Glass
Old Jan 17, 2011 | 09:07 PM
SIIKAP2's Avatar
Default Tinting Wind Visor Glass
Has anyone removed the wind visor glass (or even the entire bracket)?
Instead of putting the S2000 sticker on the glass, I thought it would be more unique to have an extra S2000 badge adhered to it. I also am considering tinting that piece of glass so it will make the badge stand out a little more when the top is down. I was at my storage unit this afternoon letting the car run a bit and decided to check it out and see if can be easily removed. After looking at it, it doesn't seem that straight forward to me.. Does the whole bracket piece just snap into the top of the console? Are there any easy tips that could be provided in removing the bracket for the glass?
Thanks in advance for your input.
Steve
Old Jan 17, 2011 | 10:02 PM
hypforlife32's Avatar
you dont have to do glass if you dont want too. my local tint shop tinted the plastic. the only reason is came off is cause my dad hit it with his arm and peeled the corner of it so it tore it off(plastic flapping in the wind). it should be extremely cheap, 10-20 dollars to get it done, i had a sticker on top of that which looked good.
Old Jan 18, 2011 | 03:26 AM
jaundice's Avatar
Pull the two plastic pieces off and there are 2 screws under those. Remove those 2 screws and the whole thing comes off.
Old Jan 18, 2011 | 09:08 PM
SIIKAP2's Avatar
Thank you for your tips and opinions. I'll post some pictures when i get it completed.
RolMaster
Feb 26, 2013 01:58 AM
s2000maniac
Nov 9, 2010 01:28 PM
moonliver
Jan 31, 2010 07:19 PM
s2kinfinite
Nov 5, 2004 09:57 AM
mbilderback
Mar 31, 2004 05:46 PM
