so let get this straight...
Old Nov 8, 2010 | 09:05 AM
s2000maniac's Avatar
Default so let get this straight...
in order to fit a glass window top to 00-01 s2k's, you have to modify the frame? Or is it a direct bolt on. If modification is required, what exactly do you have to modify? thanks
Old Nov 8, 2010 | 10:11 AM
VilleS2K's Avatar
Thanks to a couple local guys on the forum, I recently got my plastic top upgraded to an E-Z On HV denim glass top.
It's basically a minor modification. If you order the top made specifically for the MY00 and MY01 (I believe Robbins also has one specifically for MY00 and MY 01), you get two extra straps, rivets and instructions in a separate bag. The straps attach to the fourth and last bow that sits in front of the glass window when the top is up, to the car's frame below. If you don't attach these straps, the fourth bow slids forward, making the glass window sag. When you attach them properly, they pull back on the fourth bow as you put the top up, keeping the bow where it should be - directly in front of the top of the glass window. This way, the glass doesn't sag and is held up.
I know that's a detailed explanation, so hope it all makes sense. And by the way, upgrading to a glass top makes the car look so much cleaner!
Old Nov 8, 2010 | 10:30 AM
hey thanks.... i was thinking about getting this soft top >> http://cgi.ebay.com/ebaymotors/HONDA-S2000...sQ5fAccessories
and then take it to a shop that specializes in soft top etc...and let them do the modification.... what ya think?
Old Nov 8, 2010 | 10:45 AM
VilleS2K's Avatar
I can't visit eBay at work, so I'm not sure about the top. I'd go with the least expensive E-Z On (comes with a five year warranty) on topsonline.com. That's the one I got, and I'm happy with it. Trim/convertible top shops wanted almost $1,000 for installation, so I found some local guys on the forum that do it on the side for $350. I'd shop around first, and try to find someone that's reasonable and reputable.
Old Nov 8, 2010 | 12:44 PM
TPhong's Avatar
https://www.s2ki.com/forums/index.php?showtopic=99683
Old Nov 9, 2010 | 01:28 PM
bryanwells9's Avatar
i own an 01 and i got the robbins glass top to fit without any problems (and the robbins top quality is GREAT!)
^and use his DIY ^
reedkr2
Jul 16, 2008 08:59 AM
ali3nation
Dec 6, 2006 07:43 PM
s2kinfinite
Nov 5, 2004 09:57 AM
WyattH
Oct 16, 2004 10:02 AM
marcucci
Sep 19, 2001 07:11 PM
