1 step colder plugs
i have searched for awhile and i cannot find a 1 step colder plug...just one of those days. i currentley am running oem plugs. they are crap because i put it new ones, the same ones it changed my air/ fuel alot. made it super lean. i have k an fipk intake, tp and t1r single. with new oem spec plugs. ngk ir ifr7g 11ks i was running 13.5 before vtec and after vtec 14.2 and a 16.0 vtec spike. i am very close to sea level. 250 ft- 100ft. what are one step colder plugs in comparsion to the ngk ir's. thanks in advance
you can find NGK heat range 8 plugs, I know they are available and others have used them on this forum. Try a search the part numbers escape me right now.
I'm surprised your setup is running that lean, these cars run so rich I wouldn't expect that much of a difference. Might consider an adjustable fpr, I don't think plugs will be the answer to your issue, once you get the fuel addressed the stock heat range should be sufficient. Heat=power, if you remove too much heat from the combustion chamber you end up losing power.
Yes those are good ones to go with.
If you want to buy them this seems to be the cheapest place to buy from.
That's where I bought mine from.
http://www.bonanzle.com/booths/ngk/items/4...__stock___2668_
Nothing at all wrong with the Denso's. There was a issue a few years ago where by a few people reported the ceramic insulation cracked but this was traced to incorrect installation. I've run plenty of set of both the Denso and NGK's and never had a problem with either, we just get whichever we can the cheapest.
For the price of the NGK's listed in the above link I would jump at the chance and purchase them without hesitation.
