Advice on Transmission and Differential Fluids.
Hey Everyone,
While I know there is many sources of advice on here regarding this topic, I just wanted to post up my personal story to see if I can get some feedback regarding my car. I own a MY00 with 28,500 miles on the clock and was wondering if for the 30,000 mile mark it would be worthwhile to change out the transmission and differential fluids. I use Mobil 1 Synthetic Motor Oil and was also wondering if anyone had experience with their differential fluids or if they had their own recommendations? While 30,000 miles might be too early for these two maintenances (note: I could be wrong), I figured with the car just turning 12 years old (and I'm pretty sure the original owner changed them out at 15,000 miles) that I might as well just change my Transmission and Differential fluids at the same time every 15,000 miles (because I am going to be doing 15,000 miles a lot more often then the original owner did haha. Any help would be greatly appreciated, thanks for your time!
Tyler
Tyler
Absolutely change them out. Transmission fluid interval is 15k and diff fluid is 30k. However your car hasn't been driven too many miles so it's likely the fluid in there now is OLD. It can never hurt to change the fluid early, but it can certainly hurt to change it late.
5 quarts of Mobil 1 Synthetic 10w-30 Motor Oil
1 OEM Spec. Oil Filter
2 Bottles of Honda MTF
1 Bottle of Mobil 1 75w90 Synthetic Gear Oil.
I will post on the difference that this combination makes for future references to other people with similar questions.
here...
the time of owning the s i have put this together, hope it will save you some time. Some are diy and some are random stuff.
intake aem
https://www.s2ki.com/forums/index.php?showtopic=171067
https://www.s2ki.com/forums/index.ph...pic=284873&hl=
https://www.s2ki.com/forums/index.ph...#entry12038951
rtv for tears in soft top
https://www.s2ki.com/s2000/topic/850...#entry20332736
elastic straps and soft top cleaner/conditoner
http://www.modifry.com/products/index.htm
to fully detail the S
http://home.comcast.net/~michael.coh..._Hand_Book.pdf
how to clean itc valve
https://www.s2ki.com/s2000/topic/492...ean-iac-valve/
over flow tank
https://www.s2ki.com/s2000/topic/850...#entry20367565
how to flush the coolent
http://forums.s2kca.com/showthread.php?t=12152
transmison
https://www.s2ki.com/s2000/topic/565...ansmission+diy
rear diff
https://www.s2ki.com/s2000/topic/348...al+diy__st__25
motor mounts
https://www.s2ki.com/s2000/topic/803...#entry19130808
buzz after installing aftermarket exhaust (fix first link is the fix)
https://www.s2ki.com/s2000/topic/549...#entry12041341
https://www.s2ki.com/s2000/topic/365.../#entry7156985
Vented hood
https://www.s2ki.com/s2000/topic/523...s-vented-hood/
https://www.s2ki.com/s2000/topic/324...l__vented+hood
why you want 0w-30 or 5w-30
https://www.s2ki.com/s2000/topic/875...30-weight-oil/
https://www.s2ki.com/s2000/topic/877...0cc-injectors/
intake aem
over flow tank
transmison
rear diff
motor mounts
Vented hood
While I have no preference in oils, would it be okay to switch around and use Amsoil rather then Mobil 1 oil? I try to keep everything pretty uniform as I am pretty anal about my car. Also, I know some people use 5w-30 and some use 10w-30 motor oil, considering I live in the Philadelphia suburbs and it can get pretty cold here but not freezing, should I use an oil with higher viscosity like 5w-30 rather then 10w-30 (I could be wrong on the viscosity and have it flipped). Either way I'm open to recommendations. Just want to keep this car in tip top shape as even though I bought it to drive it, I want to make sure that it is well taken care of for all the miles I put on it.
Thanks for your input!
here...
intake aem
over flow tank
transmison
rear diff
motor mounts
Vented hood
intake aem
over flow tank
transmison
rear diff
motor mounts
Vented hood
For transmission i used gm synchromesh and it works great. i read the reviews for it on here and people loved it. made my tranny smooth and all the knotchy-ness was gone. for the diff i used valvoline 75w-90, but heard great things about redline and amsoil.
best in my opinon.
engine oil
1) amsoil
2) royal purple (even tho its over rated now)
3) castrol edge
-i never run mobile one anymore. my ap1 burns oil a LOT of mobile one, like a quart 1200 miles.
transmisson fuild
1) gm synchromesh
2) redline
3) honda mtf
rear diff
1) redline
2) amsoil
3) LE Almasol
best in my opinon.
engine oil
1) amsoil
3) castrol edge
transmisson fuild
1) gm synchromesh
2) redline
3) honda mtf
rear diff
1) redline
2) amsoil
3) LE Almasol
