Sponsored by: CARiD
Aftermarket header issue
Old Oct 27, 2009 | 06:09 PM
Jacksparrow's Avatar
Default Aftermarket header issue
Hey guys I just recently installed my private label header and have been having an issue with the header/cat, on the bottom there is a small opening between the header and the cat(in between the dounut gasket). Anybody ever have a similar problem to this and found a solution?
-Thanks
Old Oct 27, 2009 | 06:21 PM
wiley_s2k's Avatar
How big is the gap? Any pictures? I had a similar issue with my header(non Private Label) but all it took was a little tug and wiggle. Make sure that the gasket is properly in place and not backward or something. Hope this helps.
Old Oct 27, 2009 | 06:22 PM
prancer's Avatar
Sorry this post is unrelated and doesn't help you at all, but... are you on NSXprime? I am fairly certain there is someone on the forum that has your login name.
Old Oct 27, 2009 | 06:28 PM
^the opening is big enough that I can stick a flat head screw driver in it. I even tried taking the springs off the cat and adding a spacer to close it and it still leaked air. and for the 2nd post sorry im not on nsxprime =)
Old Oct 27, 2009 | 06:32 PM
wiley_s2k's Avatar
Hmmm...
Hopefully someone else can help out here.
Old Oct 27, 2009 | 06:40 PM
yea im thinking i installed the donut gasket wrong... what I did was stick it on the header first then tried to connect it to the cat was i suppose to stick it on the cat first then connect the header?
Old Oct 27, 2009 | 06:47 PM
wiley_s2k's Avatar
Well the gasket is kinda V shaped if I remember correctly. Are you sure that it is seated in the right way?
Old Oct 27, 2009 | 07:00 PM
integlspwr's Avatar
the issue here is that the header does not have that extra lip that the oem header has to bring the donut gasket closer to the test pipe / cat.
Old Oct 27, 2009 | 07:15 PM
wiley_s2k's Avatar
Old Oct 27, 2009 | 09:50 PM
Yes that part^ right at the bottom there is a small opening
