Aftermarket headers help with battery heat shield
Hello world
I need help I have been searching on google but can’t seem to find the help I search for. I picked up some Skunk2’s headers and I read that the black OEM heat shield that protects the battery / fuse box area from the heat coming off the engine. Wont fit back on after installing the headers what’s the best route to go to protect ac lines fuse box and battery. Would The J’s racing heat shield from Evasive work well for my problem Or is their any vendors on forums like alloy still produce parts for protecting stock battery location and fuse box please post link or pm thank you in advance for any help that anyone can provide. |
help ?
mine is still installed with skunk 2 headers? never heard of them not fitting before.
Originally Posted by outeiroj
(Post 24611087)
The oem battery/ fuse box heat shield or js racing You have with your headers also is it possible to pm or post photo I got the info from here 4th post by “legros” https://www.s2ki.com/forums/s2000-un...-tips-1033868/ thank you again |
Originally Posted by Kid Ap2000
(Post 24611093)
You have with your headers also is it possible to pm or post photo I got the info from here 4th post by “legros” https://www.s2ki.com/forums/s2000-un...-tips-1033868/ thank you again https://cimg7.ibsrv.net/gimg/www.s2k...1d5c07825.jpeg also i purchased a J's racing shield and returned it because the bolt holes did not line up and the bends were wrong |
(Post 24611107)
seems as though the threads points to having them removed to physically install however makes no mention of them having to be removed permanently.
https://cimg7.ibsrv.net/gimg/www.s2k...1d5c07825.jpeg also i purchased a J's racing shield and returned it because the bolt holes did not line up and the bends were wrong Can you get a top view of the factory battery heatshield and headers? I wanna see clearance if you don’t mind and you also have the alloy battery heat cover also thanks for letting me know on the js racing saving me money the guy in the post said “Cannot reinstall “ thats the only post I came across noting that I don’t want to work double so I been stuck there trying to find help on google but couldn’t that’s the only thing holding me back from the work I’ll give it a attempt tomorrow hope all is well I’ll post photo of my dirty stock engine bay once completed if completed Might you say no issue then it’s a go lol thank you again |
I’ll take a picture when I get home but I don’t have any clearance issues
(Post 24611179)
I was stressing on not being able to run a heat plate for my fuse box and battery and ac line thanks for your help I’ll be doing the work later today on a lift hope it goes well also how can I post photos on here that way I can add photos of the work/ finish product once done |
I'd do a header wrap as probably the cheapest option. I have a PLM header, which I'm told is a cheaper knockoff of a J's Racing and it fits fine.
Originally Posted by HondaTN
(Post 24611383)
I also have a vents on my hood which might help with the heat |
