airbox mod
Agree. I'm leaving my intake alone. Not interested in reduced performance and increased noise which just attracts attention.
The small elbow-tubing/divider hole, is the same size as the small front-opening hole. So, I really doubt removing the divider and elbow-tube will really make an improvement; because the front-opening is still small and still the same size after-all. Both of those small holes working together is probably designed to decrease sound (like a muffler or gun silencer) and also decrease turbulence and smoothen airflow. Removing only 1 of those small holes (the divider and elbow) won't increase flow; because the front opening is still small.
Fokker what do you do to combat heat soak? I live in a hot region too (never freezing) and I do suffer heat soak (stock engine). I have researched this topic but found too many conflicting opinions.
The intake tube and box are wrapped in DEI Reflect-A-Gold tape. The intake temps dropped significantly while sitting still (~10-15 degrees) and the numbers stay very low while moving air through the bay (driving).
Stock airbox is designed to suppress intake 'noise', while not compromising performance. Its very well designed for that purpose. The trouble is, most of us would consider that desirable sound, not noise.
Hence the popularity of aftermarket intakes, which provide very little if any performance gains, but sound great. While there are possible performance gains from an intake, they're minimal. The odd looking puffo has documented, minimal gain, and lengthening the intake tube, AFTER the filter has proven, minimal gain.
The mod in the youtube does not appear to compromise anything other than 'noise' suppression. Its free. It does not make the car look riced, so does not reduce cars value for not being 'stock'. There are not a lot of downsides to it.
Note, while intakes that lengthen intake tube after the filter have proven gains, lengthening the feed into the filter would not have the same effect. Likewise, removing the stock box tubes in the lid isn't going to compromise performance.
Let's see a dyno without aftermarket header, aftermarket tune nor any other parts added. Then I'll believe if the mod works or not. It's not that hard to do and I wonder why no one has done it in 18 years, lol.
Because no one really believes it will have any measurable effect, so they know its a waste of time.
Its for sound, and possibly cooler air (which can provide better throttle response, but no real performance potential here either over stock box).
