airbox mod
Ok, notwithstanding my somewhat negative comments above, I have a used oem air box on the way from a member part out. I'll try the air box mod. Just for fun. I'll be able to slap my original box back in if I don't like it.
I'm not expecting anything of consequence except sound. I remain unsure if I really want to be attracting attention with sound. But, what the heck - I'll give it a whirl.
Bro-Bob: how the heck do you fit that power tool in the box? Does the bade angle rotate so you can hold the tool vertically while cutting?
Maybe I'm paranoid? But, with a stock ecu in an ap1 - is there any concern that increasing the air flow, (which this simple mod does not seem to do), would lean out the mixture and and burn valves?
Project S2000: Part 20 - Stock Air Box Modifications And Not Going Faster
Project S2000: Part 19 - Ram Air!!! Plus Hot Air Testing!
Slight fault in my setup in that I didn't plug the hose going to the front breather of the valve cover, so I was blowing pressurized air into the valve cover.
Next time at the track, I plugged that hose and gained some more pressure gain.
Project S2000: Part 22 – Testing New Goods and More Intake Mods
Already tested, doesn't do anything significant:
I recall reading thay excellent motoiq article on more than one occasion. Well done.
In that article it was noted that after internal airbox modes revealed no real difference in air pressure (read, no relief of any restriction), a test with airbox lid removed showed a real improvement in this area. Of course, the overall effect was a big loss in power, since as everyone knows it also allows hotter air into intake. One step forward, three steps back.
But what this shows is there IS still an airbox restriction. That small rectangular intake opening at the front of box. Bigger opening would be an improvement (Honda probably didn't make it bigger to remain compliant with noise targets).
The idea proposed here is to add a HUGE 6 inch hole in the lid, along with an elbow that would act as a scoop (as a prototype. If it works then a hood with a decent looking scoop would be fabricated). The stock rectangular front opening would be blocked off.
The stock rectangular opening is probably equivalent to something around a 2.5" hole (I did the math once, this is what I recall). So a 6" hole is much more than twice the size of stock opening. It has the added benefit of coldest air possible, and no added twists or squeezing through narrow sectuons like snorkels added to fromt of box have to deal with.
So the proposal should yield measurable improvement in intake pressure. Whether that translates to measurable power increase is another matter. Perhaps Honda found it added noise and only a little power. We might prefer them both. So I'd still like to see what results.
LHT claims the airbox mod is beneficial. And claims they've confirmed it on the track. Can't tell anything from their dyno test as they also have a Skunk header (and they're on a DynoJet which is hardly conservative).
-- Chuck
-- Chuck
I don't see anything wrong with the oem air filter either, it has a built in air horn and is more than large enough for the size of the engine, and filters better than cotton gauze filters IMO. I recall Xviper (Dave) once stated that the S2000 filter had more surface area that the two air filters on his Viper combined.
