alignment with coil overs
it is recommended that you do at least get an alignment when you changr ride height. just set up the height to where you want it then get an alignment after. most people i know set it to their desirred height and never adjust again
All in all, what kind of height diff are we talking about here. i mean if your gonna move it up and down maybe a cm or 2, then your fine althoughas mentioned every time you move it, It will throw it off.
Ive had mine aligned and then ive had it up and down a few trimes, Had it re aligned to find out that nothing honestly changed. I was susprised to see a minimal change or .2/3 ina few area's so back to how I started this,
It all depends on how you go up and down and how far.
thanks guys yeah i changed out my suspension a while ago and set it to a good height but of course once said and done things settle and it dropped quiet a bit and i started to hear rubbing so i needed it raise it back up a 1/8 inch
anyone think i should get a new corner weight also? i do take it auto x every once and a while
