Sponsored by: CARiD
Ap1 to Ap2 front
Old Sep 4, 2011 | 02:39 PM
rugsr's Avatar
Default Ap1 to Ap2 front
Tried finding in search and couldn't
I'm buying a ap2 front bumper and hardtopguy says you also need a 04+ splash guard. Is this true? I would like to not cut/modify up MY00 splash guard to fit so if it's not direct bolt up then I guess I'll buy one.
Before I order it is it truly necessary?
http://www.hardtopguy.com/store/prod...&cat=26&page=1
Old Sep 4, 2011 | 02:42 PM
Vinsfeld's Avatar
No it is not necessary. The DIY guid that answers your questions should be in S2k Modifications and Parts sub forum at the top in the stickies.
Old Sep 4, 2011 | 03:38 PM
suzuka-blue-s2k's Avatar
Yeah you do not need it. The reason they say that is because a few of the holes don't line up 100%, most of the bolts do line up though. With the ones that aren't lined up just use some good zip ties and it will be fine.
Old Sep 4, 2011 | 04:16 PM
funkemonke's Avatar
also, look into getting the ap2 support beam b/c the ap1 beam will poke through the bumper causing it to crack. i heard its like $50 for that peice and is held by 2 bolts.
edit: its not $50, its $124.30.
item 11
http://www.hondaautomotiveparts.com/...tcgry5=BUMPERS
Old Sep 4, 2011 | 05:52 PM
blobianco's Avatar
No sir you dont just zip tie the bottom to your splash gard, I can take pics if you would like!
Old Sep 4, 2011 | 06:02 PM
item 11
Most just grind or cut off the edges which is very easy to do and it's free, that's way better than spending $125+ on an ap2 beam.
Old Sep 4, 2011 | 06:07 PM
rugsr's Avatar
If you could take pics that woils be great.
Thanks for letting me know about the metal piece behind the bumper. I'm keeping all my stock parts incase a stock S2000 is worth coin someday, maybe I'll buy part 11, maybe I'll grind it down....hmmmmm
Also the grills are different between ap1 and 2s correct? Part 3
Old Sep 4, 2011 | 06:36 PM
Yep, ap1 and ap2 grills are different.
Old Sep 4, 2011 | 07:02 PM
rugsr's Avatar
Afraid of that
Old Sep 4, 2011 | 07:07 PM
woodburn's Avatar
There a DIY on here somewhere that explain everything you need to do. Ill see if i can find it.
