Sponsored by: CARiD
ap1 headlights on ap2
Old Jul 30, 2011 | 11:02 AM
K.Shift's Avatar
Default ap1 headlights on ap2
Hey guys..i was thinking about swapping my ap2 headlights( in bad condition) for some ap1 headlights..
i just have a question..
-will my ap2 ballasts and ignitors/etc work and fit in the ap1 headlight housing alone? will it be simple plug and play? Or will i be needing the ap1 ballast?
i ask because ive searched for a while now..and its always been the other way around..ap2 headlights on an ap1..and i know what modifications need to be done with the ballasts and etc...so i just wanted to clarify for ap1 headlights on an ap2..it may be a downgrade..but ive always liked the way ap1 headlights looked on an ap2 bumper.
any info would be appreciated.thanks!
Old Jul 30, 2011 | 11:29 AM
FormulaStwoK's Avatar
only seen it the other way around. Are your headlights cracked broken or just foggy?
Old Jul 30, 2011 | 12:16 PM
woodburn's Avatar
ill trade you...ap1 for ap2
AND CASH MONEY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!PM IM WAITING
Old Jul 30, 2011 | 02:28 PM
K.Shift's Avatar
ahhhh.I seee..but if I do a full swap..with ballast and everything included..it would be plug and play?
Old Jul 30, 2011 | 02:33 PM
steven975's Avatar
no, the headlight is the housing only.
You need a full set of AP1 headlights...ballasts, bulbs, housing, all of it. You really should just trade for a full AP1 set so you don't have to do some ghetto rigging.
I'll add my name to the list of people that will trade you AP1 lights for AP2.
Old Jul 30, 2011 | 03:42 PM
DFWs2k's Avatar
Bulbs are the same, you dont have to change bulbs
OP, make sure you are getting cash + headlights, unless you want to swap with me
Old Jul 30, 2011 | 08:18 PM
K.Shift's Avatar
thanks guys for all the info and the heads up..i currently found someone local who is gonna swap his full ap1 headlights (ballast..ignitors..bulbs..etc) for my ap2 headlights( lens are in bad condition and leaks)....if it doesnt fall through..ill definately hit you guys up!!
Old Jul 31, 2011 | 10:20 AM
chViETnk's Avatar
if you swap, its direct plug and play, i believe it should be easier to put together ap1 headlights with ap2 ballast because ap2 wire is smaller opening and will fit into the bigger ap1 housing opening. everything will plug up. the only problem you will have is to get some metal strips or something to fab up mounting mounts and to seal up the extra space where the ap2 ballast wires go into the ap1 housing.
edmundo528
Mar 16, 2007 07:01 PM
rikhemi
Nov 17, 2006 03:48 AM
sleek6mt
May 27, 2006 12:41 PM
