Sponsored by: CARiD
Ap1 Oem front lip
Old Aug 31, 2017 | 01:39 PM
crxswap's Avatar
Default Ap1 Oem front lip
Does anybody have any pictures or info on these? Ive searched but not much info/pictures. I am purchasing a front lip and it seems to be OEM. Metal brackets to connect to bumper, that bolt to the lip. Ive seen some picture and it looks like the same brackets, but they were riveted on. Also can't seem to see any markings or part numbers. Just trying to get some info. Thanks!
Old Sep 1, 2017 | 08:32 AM
AngryTurtle's Avatar
If it is brand new its not OEM.
Old Sep 1, 2017 | 08:37 AM
dc2-2-ap1's Avatar
Oem ap1 lips will have plastic brackets riveted on with plastic rivets. If you aren't selling your first born for it, it probably isn't oem. They were discontinued years ago and demand has skyrocketed the price.
Old Sep 1, 2017 | 09:25 AM
crxswap's Avatar
Okay as I keep researching this, I'm finding that they do indeed have metal brackets either riveted or bolted to the lip. In the images I have found both configuration have Honda stamped on them. I've not seen plastic brackets yet.
Old Sep 1, 2017 | 05:26 PM
jwbavalon's Avatar
My OEM lip has metal brackets riveted to the lip. The metal brackets have Honda numbers stamped on them (they are not part numbers). The installation instructions are available as "Front Under Spoiler" publication # A11 20592. The hardware to mount the lip to the bumper is still available from Honda as it is the same as the AP2 hardware (90305-SH3-000, etc ). As it is OEM it takes minutes to install because everything lines up.
Good luck.
Old Sep 1, 2017 | 07:27 PM
crxswap's Avatar
Here are some pics a a questionable lip Im looking into. Anybody know?
Old Sep 6, 2017 | 12:43 PM
crxswap's Avatar
Where are all the Oem Honda guys at?? If anything the hardware looks oem.
Old Sep 6, 2017 | 03:07 PM
Hfreak's Avatar
Here are the Honda mounting instructions, hope it helps in identifying what you need to.
https://www.handa-accessories.com/S2000/s2kfuspoil.pdf
Old Sep 12, 2017 | 06:27 AM
shy_guyAP1's Avatar
I think that's the exact same lip I have, I used the Honda 10mm bolts and washers from when I had an OEM lip before it got destroyed. They line up pretty well to the OEM mounting points for the lip.
Old Sep 12, 2017 | 03:15 PM
Sylvain2000's Avatar
Ap1 Oem front lip-photo737.jpgAp1 Oem front lip-photo718.jpgAp1 Oem front lip-photo760.jpgAp1 Oem front lip-photo604.jpgAp1 Oem front lip-photo686.jpg
This
