AP2 2004 TO AP2 CR SWAY BARS SWAP
i was planning on getting myself a CR sway bars but im not sure if it would make a difference on running on my ap2 2004.
I only have a couple question regarding swapping to CR sway bars
1. will it make a difference?
2. will it work without any modification to my car?
3. is it worth it?
wheel and tire specs
17x7.5 225 falken azenis
17x9.0 255 falken azenis
swift springs. drop 1. rear and .8 front.
3. is it worth it?
I have stock AP2 suspension with a CR front sway. I can tell you it puts a lot more understeer into the car, at least with the stock ap2 rear sway. I liked the results though it takes a bit more to put the rear out.
MY00-01 AP1 rear sway is very very close to the CR rear sway in stiffness. The MY02-03 is a little softer than the MY00-01.
So, keep your stock rear sway and consider a stiffer front bar. The CR front sway would probably need to be matched with the CR springs/shocks to have a dramatic impact. You might consider a Saner, Cusco, or Whiteline front sway instead.
Toneezy
Bay Area For Sale
May 27, 2013 03:54 PM
Artric
Dec 8, 2009 01:23 PM
