Sponsored by: CARiD
AP2 Custom Exhaust
Old Mar 31, 2012 | 08:25 PM
thesilverbullet's Avatar
Default AP2 Custom Exhaust
i'm planning to create a custom single "short" exhaust so i can mount the stock tips.
what's the best 3" straight through resinator and muffler?
i plan to mount the resinator in the cat/test pipe location and the muffler in the resinator location with a turn down tip under the car. i removed the muffler section of my 70mm invidia N1 single and mounted the stock tips using black pvc pipe and treaded rod. looks stock and i love it. just need to put in a custom exhaust that will locate behind the rear axle or side winder mount.
Old Apr 2, 2012 | 09:39 AM
Gernby's Avatar
Former Sponsor
If you want to keep a lowered VTEC engagement, you cannot put a resonator that close to the header. A big resonator where the stock cat goes will create a huge dip in torque at about 5K that is just about as bad as the stock cat.
Old Apr 2, 2012 | 09:41 AM
Gernby's Avatar
Former Sponsor
... that's why no reputable company should be producing resonated test pipes.
Old Apr 2, 2012 | 05:28 PM
thanks for the tip. so now i'm planning to just put in a muffler in the area of behind the axle with a downward tip. unless i can find room for both down stream from the tp.
Old Apr 3, 2012 | 07:16 AM
Gernby's Avatar
Former Sponsor
If put a big muffler where the stock resonator goes, with a turndown tip right by the axle, your drone RPM will probably be at a higher RPM than it is for typical S2000 exhausts.
Old Apr 8, 2012 | 06:22 AM
i can deal w that
what's the best straight through 3/3" muffler? - vabrant, Exoticspeed R1-Titan, megan mvo-t, magaflow pro series, flow-pro, ebay?
Old Apr 8, 2012 | 09:40 AM
cadams05nfr's Avatar
Im sorry but this sounds like it would be ghetto as hell. But to each his own I guess.
Old Apr 9, 2012 | 03:34 PM
maybe -
looks wise - it will look stock
sound wise - i think i'm alread y there (look and sound wise). running a invidia 70mm single - lol
i dropped off the muffler section of the invidia single and the resinator is not bearable (like the N1 single is - lol). So i have determined i need a decent muffler. i'm basically will be running a short verison of the berk 3" headerback exhaust system with stock tips... so i will only sound ghetto instead of look and sound like ghetto with the single...
austincrx
Jun 26, 2013 12:03 PM
lolls
Jul 10, 2012 10:37 AM
Ness2k
South Florida
Aug 4, 2007 04:41 AM
nautica602
Sep 4, 2005 04:12 PM
SilverKnight
Aug 16, 2005 08:05 PM
