Sponsored by: CARiD
AP2 FLYWHEEL WEIGHT/AP1 FLYWHEEL WEIGHT
Old Sep 21, 2009 | 05:21 AM
M2K's Avatar
M2K
Default AP2 FLYWHEEL WEIGHT/AP1 FLYWHEEL WEIGHT
Anyone know why does AP2 flywheel weighs more than Ap1 by a significant amount.
Some members uses AP1 flywheel with their aftermarket clutch in and ap2.
What is the advantages of having a lighter flywheel and why AP1 FLywheel?
Old Sep 21, 2009 | 06:04 AM
spets's Avatar
It probably works with the clutch delay valve to lower the drivetrain shocks by slowing down the shifting.
A lighter flywheel means your engine is going to free rev faster. if you're rev matching on a down shift the engine will get there faster. If you go with too light of a lightwheel though, daily stop-n-go driving will be tough.
Old Sep 21, 2009 | 06:09 AM
//steve\\'s Avatar
I think most people use the ap1 flywheel b/c it's lighter but not too light and b/c its oem. Oem is almost always best.
I know if I ever have to replace my clutch I'm removing the delay valve and putting an ap1 flywheel in there.
Old Sep 21, 2009 | 06:16 AM
M2K's Avatar
M2K
i am going to use ap1 flywheel then.
I dont know about taking off the delay valve if its for safety purposes, to safeguard the tranny.
anyone with AP1 flywheel here with an AP2? Does it chatter?
Old Sep 21, 2009 | 09:01 AM
B serious's Avatar
The clutch is what causes chatter, not the flywheel....unless the flywheel is greasy or warped or something.
Old Sep 21, 2009 | 03:19 PM
jp8ap1's Avatar
i thought they are the same i looked at the part numbers and stuff and they match up, they are both 22100-pcx-005. Actually the Clutch, Flywheel, and Pressure plate are all the same part numbers
Old Sep 21, 2009 | 03:27 PM
koukikat's Avatar
[QUOTE=jp8ap1,Sep 21 2009, 07:19 PM] i thought they are the same i looked at the part numbers and stuff and they match up, they are both 22200-pcx-005.
Old Sep 21, 2009 | 03:30 PM
koukikat's Avatar
No it does not chatter, go drive an AP1, that's how it'll feel. Same PP an disk, just lighter flywheel and no crappy CDV.
Old Sep 21, 2009 | 04:20 PM
Sebringer's Avatar
I'm pretty sure the AP1/AP2 flywheels are 14/22 lbs, respectively.
I'm considering the Comp. Clutch 11.5 pounder. About the same price as a new AP1. Not sure what the 'ideal' weight is though for our car for combo street/occasional track duty. Have gotten differing opinions. Based on what people have said, I'm surmizing that 10-12lbs is the zone.
A little extra work, but I will have the flywheel and pp balanced at a local machine shop. Guess they could always lighten the AP1 a couple of pounds, too (not sure).
Old Sep 21, 2009 | 04:45 PM
jp8ap1's Avatar
Originally Posted by koukikat,Sep 21 2009, 03:27 PM
No that's wrong, the pressure plate and disk are the same part numbers, but the flywheel part numbers are completely different. AP1 flywheel is aprox 7 pounds lighter than the AP2
my bad i was looking at the clutch part number, is it a different design or just the weight is different? is is possible to use the ap2 flywheel with the ap1 tranny?
