Sponsored by: CARiD
From Ap2 headlights to Ap1 ? Do i need anything?
Old Feb 11, 2011 | 09:15 AM
kaansahbaz's Avatar
Default From Ap2 headlights to Ap1 ? Do i need anything?
Do i need anything when going from AP2 to AP1 headlights ? it will be a full swap ie: my housing,ballast will go, and i will get ap1 housing and ballast. any wire or anything needed in this process?
TIA!
Old Feb 11, 2011 | 09:17 AM
suzuka-blue-s2k's Avatar
The ap1 swap is just like doing an ap2 swap, you will need the ap1 ballast and ignitors, and also the wire coming off of the ignitor. If you have all this everything will be plug and play.
Old Feb 11, 2011 | 09:24 AM
kaansahbaz's Avatar
Does the ignitor come on the headlight housing? i will do a swap with a member so i am trying to figure what i need from him and what i need to give him as well to make it work. so when i am posting "for trade" thread i ll put it down as housing+ballast+ignitor...
Old Feb 11, 2011 | 09:28 AM
Yes it is screwed onto the headlight housing. I actually traded a guy my ap1's for some ap2 lights and we both took the headlights out, and just unplugged everything and took the bulbs out (you will leave your bulbs on your wires, these will go right into your new ap1 lights). The wire i'm talking about it plugged into the ignitor, and is maybe 6" long then has a connector. Just unclip it right there so you have the wire hanging off the headlight, and that is all you need. You should receive the other headlights exactly the same way and it will all plug in.
So yes you need the housing, ballast, ignitor, and the wire coming off of the ignitor.
Old Feb 11, 2011 | 09:40 AM
kaansahbaz's Avatar
That was very helpful dude! second time saved my life
K.Shift
Jul 31, 2011 10:20 AM
shogunboi
Oct 23, 2009 05:26 PM
danielxjc
Jun 15, 2007 07:14 PM
rikhemi
Nov 17, 2006 03:48 AM
