AP2 Rear Sway bar delete mod
Any Ap2s Daily Driving their car with no rear sway bar mod?
Pros?
Cons?
Im on the fence about doing this to my 05 AP2. I will have Swift Spring on stock shock/struts next week might take it off since I'm back there.
Pros?
Cons?
I had that option when was non staggered. Asked around and did some research. Was mostly told that the car feels "disconnected" in the rear and feels "off". So I just bought a 32mm Cusco front sway bar.
Swaybar = spring stiffener only when turning
Remove bar = same as just running a softer spring rate in the back
Bigger bar up front = stiffer springs in the front
Get the rate of the swift springs call GC get custom rates with what I just said above in mind
Pretty much the same experiance here. If you NEED to reduce the oversteer for autocross/track I would look at this as a good temporary fix.
Originally Posted by THE_Loser' timestamp='1324747455' post='21261475
i removed my rear bar on my ap1 and it completely killed the fun factor in the car, made it understeer like crazy, but if you like understeer, go for it!
Please OP dont remove it, instead mod your suspension with some coilovers or koni yellows
