Sponsored by: CARiD
battery connection?
Old May 19, 2009 | 05:17 AM
08s2000CRbackinblack's Avatar
Default battery connection?
what type of connection will work to extend the power wire to the trunk for a relocation?
any input is appreciated, thank you
Old May 19, 2009 | 07:51 AM
Nickamsweet's Avatar
Also in for the answer on this....
Old May 19, 2009 | 09:38 AM
i dont think soldering would do the trick, but idk
Old May 19, 2009 | 10:08 AM
jeffbrig's Avatar
You should be able to find a large enough crimp connector, or look for a power distribution block like people use for stereo amp installs.
Whatever you do, be sure to add a fuse as close as possible to the new battery location. You don't want to run an unfused power cable through the car - that's a short waiting to happen if the cable gets pinched/nicked.
Old May 19, 2009 | 10:28 AM
Yeah that's a good idea, don't know why I didn't realise it... could just use a fuse block for amp install... but unsure on what kinda of fuse rating you need - (15A+)??
kinda like that ^^ ??
Old May 19, 2009 | 10:58 AM
jeffbrig's Avatar
I would put a huge fuse with the battery in the trunk(?), and use a non fused distribution block up front. Match that fuse to whatever main fuse is under the hood. (I'm assuming there's a main fuse, it may actually split into multiple fuses)
Old May 19, 2009 | 11:06 AM
The inline fuse holder would work, be a lot simpler too... just need the max ampage that the main fuse holds... so that the battery has a fuse near it... long wire through car to the fusebox...
what is the connection like from the battery to the main fuse box anyway??
Old May 19, 2009 | 12:01 PM
jeffbrig's Avatar
No idea, trace the wires and see what you find...
Old May 19, 2009 | 12:43 PM
Ian300D's Avatar
100w is what your fuse block sees and I think is what most people put on inline coming from the bimmer world. Now what I did, was go down to Walmart under their GHETTO audio section haha. They have a 2 to 1 inline fuse block. It's a whole $6.79 and get 2 of their $3.82 fuse asst kits, and slap 2 of the 100w in their. Enjoy. If anyone needs me to, PM me and I will post back up here with pics.
Importedpower
Dec 19, 2015 11:01 AM
liquidgsr
Apr 7, 2013 03:43 PM
sbrodacz
May 1, 2009 07:51 AM
billyjoho
Nov 30, 2006 08:23 AM
Goldtrom
Jul 23, 2001 02:30 PM
