Sponsored by: CARiD
Best Aiir filter?
Old Mar 14, 2015 | 12:22 PM
Apex1.0's Avatar
Default Best Aiir filter?
Oem air box and I am using a drop in k&n filter. Performance is important but I live on a dirt road so filtration is key too. Does the k&n filter as well as oem? Does the oem flow as well as a k&n? What other options are out there?
Old Mar 14, 2015 | 12:38 PM
Moddiction's Avatar
Former Sponsor
The better the filter flows usually the worse it will filter. K&n will flow better but filter worse.
Old Mar 14, 2015 | 06:09 PM
Car Analogy's Avatar
I read online a study someone did some years ago comparing k&n filter with several standard paper element filters. The study analyzed the ability to filter, not to flow.
The k&n did not fair well. It wasn't able to remove particles anywhere near as well as a normal filter.
If you have a k&n, and are concerned, just get an oil analysis, which will tell you if too much is getting past the air filter.
Old Mar 14, 2015 | 06:47 PM
zeroptzero's Avatar
I'd stick with the oem filter, it's surface area is more than enough that it can flow more air than a stock engine needs. It also has an air horn built into the base of the filter, and not all of the K&N filters have that. The oem unit will filter air better than a K&N. I see no benefit in changing to a K&N filter other than cost savings.
Old Mar 14, 2015 | 09:03 PM
Habitforming's Avatar
This. Not exactly the point of OP's question, but often overlooked. K&N really missed the boat on that one.
Old Mar 15, 2015 | 04:18 AM
Apex1.0's Avatar
What air horn? The k&n does not have that? I am assuming it helps for performance. So for a mild bolt on car, does the k&n outperform the oem, or is the oem better.
I will do the oil analysis next change.
Is there any air filters that flow better and filter better than oem? Sounds like no...
Old Mar 15, 2015 | 07:06 AM
Usually called a velocity stack in the states
http://en.m.wikipedia.org/wiki/Velocity_stack
For your situation I would continue to use the factory filter, and just change it more frequently than recommended.
Old Mar 15, 2015 | 08:42 AM
Apex1.0's Avatar
So I will need to buy an oem filter then. Any year good?
Old Mar 15, 2015 | 09:37 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
I run a JR filter.
2.8 microns filtering,and free flowing,and with a velocity stack.
Old Mar 15, 2015 | 10:35 AM
noodels's Avatar
Cosworth oem here
