Best Aiir filter?
Old 03-16-2015, 06:34 AM
freetors's Avatar
Here is the air filter testing that was mentioned earlier: Link. The K&N filter was one of the worst in filtering and had one of the lowest dirt capacities. Foam air filters will also perform similarly poorly. I would stick with OEM. I can't fathom why all the turbo guys run without air filters.
Old 03-16-2015, 09:47 AM
Jah2000's Avatar
The Ballade Sports K&N comes with a velocity stack. Want.
http://www.balladesports.com/product...ake-air-filter
Old 03-17-2015, 09:43 AM
Apex1.0's Avatar
OK so I did some searching on OEM air filters. It seems there are two types but one part number. Do both have a velocity stack? I guess the visible difference is the mounting post on one is an X, the other is a solid post.
Anyone know????
Old 03-17-2015, 04:13 PM
rrounds's Avatar
Also, A air filter will filter better as it loads up with dust. You just don't want to leave it on to long, so how do you know when to change it? Buy a filter restriction gauge like this
http://www.amazon.com/Wix-24801-Air-.../dp/B0014BI1KA
If you change(or clean) the fliter to often, you will let more dirt into your engine. So this is where the restriction gauge comes into play. It tells you when its time to change the air filter out. I change mine out when it shows 11" of restriction or six years.
Here are some pic's of where I put one on my '06 S
http://s188.photobucket.com/user/rod...?sort=2&page=1
ROD
Old 03-18-2015, 08:22 AM
redlineracing's Avatar
I run K&N AF's on all the cars listed below since new....without problem.
Keep 'em clean & oiled( but not too much).
\rlr
carolina
rsdub
01-24-2017 01:08 PM
Robert O
11-07-2010 12:40 PM
aznnico
05-24-2010 10:16 PM
LouisM
09-24-2006 08:38 AM
Sgt Skidmark
06-10-2005 08:31 PM
Quick Reply: Best Aiir filter?
