Big throttle body
I'm about to order a big throttle body and don't know if it would be good for my settings, if so which size and eventually brand or do i have to stay OEM.
I'ts a 03 AP1 whith MUGEN ecu,header,catback,airbox,all cooling stuff.also test pipe,4.77 gears,light pulleys,clutch and FIDANZA 8lbs fly.Sorry if my english is average i'm french so it's not that easy.
SOS throttle body is a good option too: http://scienceofspeed.com/products/e...throttle_body/
Power gains backed up by dyno charts and no mention of port matching the intake manifold (for what it's worth, YMMV)
The only difference you will see with a larger throttle body is the increased throttle sensitivity at partial throttle. The slightest throttle gives greater response.
Increasing the diameter from 62.5mm to 64mm will make a major difference. I drove a 64mm for 4 years with a 8 lb. light weight flywheel and totally enjoyed the experience. Parking on steep hills took all of my attention and a little revving to complete the task.
I'm driving a 70mm BDL now and it feels good. I am boosted.
