Sponsored by: CARiD
Blown Shocks?
Old Oct 17, 2008 | 09:16 AM
AP1rulz's Avatar
Default Blown Shocks?
Hi all, just purchased a set of Koni Yellows used w/20k miles on them; i got the shocks but this is what im encountering as far as the condition of all 4 of them:
with the adj knob on full stiff:
i can compress the piston shaft by hand with some effort and the shaft doesnt return to its original position until after a while.
with the adj knob on full soft:
i can compress the piston shaft by hand with no effort and the shaft returns at a fairly normal speed to its original position.
this is with all four!! are they blown? are they supossed to be like this?
im assuming that at full stiff i wouldnt be able to compress the shock by hand at least.
Any info or thoughts,
Thanks,
Old Oct 17, 2008 | 09:49 AM
ahrmike's Avatar
its more of a 'impulse' thing...i think
if you were to try jump on one shock on full hard it prolly wouldnt compress much..its compressing cuz youre holding it slowly..since its just fluid motion in a buncha tubes with holes...if the hole is small, its naturally hard to compress...but it will compress cuz eventually the fluid will go through.
thats how i see it neway. ;p
Old Oct 17, 2008 | 09:54 AM
AP1rulz's Avatar
i see your point;
but is the scenario im experiencing the same with new koni shocks? fairly used shocks? almost dead shocks? or dead shocks?
thanks for taking your time to answer my q's!!
Old Oct 18, 2008 | 06:30 AM
s2k dre's Avatar
if they are out of the car, u will be able to compress them so its normal, make sure they are dry in the piston area
Old Oct 18, 2008 | 08:01 AM
AP1rulz's Avatar
thanks guys; i was able to locate this video... and im experiencing the same results...
Shock test
ill take them to shop just to confirm...
Old Oct 18, 2008 | 01:50 PM
Supra-holic's Avatar
When you put it on stiff your reducing the orfice area where the oil can pass through so its going to take longer for it to return. There is nitrogen gas in there that your also compressing, that is what returns it back. This is there to reduce the formation of bubbles in the oil which could dampen (haha a pun) performance.
Keep in mind that every I said can be completely wrong. LOL
kbmass
Jun 29, 2015 03:22 PM
corpuszero
Jul 15, 2011 08:41 PM
DonJ
17
Jul 27, 2009 02:46 PM
WarrenW
May 3, 2005 05:19 AM
colatkitty
Jan 4, 2004 11:16 AM
