Sponsored by: CARiD
Build thread 2.0
Old Oct 23, 2010 | 12:42 AM
exodusx7x's Avatar
Default Build thread 2.0
So Instead of cluttering up the random thread with my build here it is:
I have already completely pulled everything out of the car.
This includes interior,seats,dash,ac,heater,soft top, doors,trunk, all wiring....... You get the picture.
Also was originally going to rewire everything but found that I will only need to rewire the inside harness. the engine harness really doesn't have anything on it and I have decided to cut cost by reusing as much oem as possible.
that was the car before tear down
As I get more accomplished I will post some more pictures.
Still have to get some pictures of the calipers that I coated black. Also Should be picking up all of the removable parts from the engine next week that were at powder coat such as.......Intake manifold, All pulleys, Water pump, the whole front end brackets and so on. Wheels will be getting dropped of at the same time as well as the valve cover and intake pipe.
as most of you know I plan on running the car extremely lean as far as weight goes. which means I will be running functional hood pins. As well as a set of trunk latches. Shaved 12lbs just by removing the front and rear latch as well as the trunk cable and assorted bolts....... More too come in the following weeks
exodusx7x
Jan 28, 2012 04:55 PM
24s2k7
Feb 24, 2006 03:17 PM
