Sponsored by: CARiD
Caling Puddy
Old Feb 2, 2011 | 07:47 AM
Kyushin's Avatar
Banned
Default Caling Puddy
I found this browsing Spoon parts and wondered the benefits it would add...
http://www.gotuning.com/product_info.php?f...products_id=297
How would the extra fluid actually get into the diff, im not sure how the lube system works back there and if you would recommend such a system, or accept one and reinforce it in your shop.
Old Feb 2, 2011 | 08:30 AM
BEASTMODE's Avatar
I'm no expert, but it seems to me like it simply provides for more fluid so that it doesnt get dirty as quickly. I dont really believe the whole lowering diff fluid temps since I doubt those gears get super hot to begin with, but whatever. I cant imagine it would hurt to have more fluid to circulate through the gears, but I wouldnt waste my money. Maybe spend it on an oversized baffled oil pan or something where it would be more useful if you want to provide extra capacity, oil cooling and prevent starvation.
Old Feb 2, 2011 | 10:38 AM
S2KPUDDYDAD's Avatar
I think it is ok for track use but street use may not be best because of ground clearance. The unit is made to hold more oil.
I make a cooling cover that is more street friendly and has a much larger heat sink.
Old Feb 2, 2011 | 11:42 AM
cenix's Avatar
very nice.
Old Feb 2, 2011 | 05:01 PM
zeroptzero's Avatar
S2KPuddydad, what do you think about running 75w140 diff. fluid in a stock differential for a daily driven S2K in stock condition 3 seasons of the year ?. I just put in Amsoil 75w140 to run in the upcoming season once the car gets put back on the road in spring. Any opinions on this viscosity ?. thanks for any replies.
Old Feb 2, 2011 | 05:15 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
+1,would like to know too.
I use it in mine,with 4.56 Richmond gears,and it seems to attenuate the noise.
Old Feb 2, 2011 | 05:57 PM
The 75/140 is over kill in a stock rear 75/110 by Amsoil is what I like and use my self. With 4.56/7 gears 75/140 or SAE 190 by Amsoil is good choice.
Old Feb 2, 2011 | 06:16 PM
zeroptzero's Avatar
[QUOTE=S2KPUDDYDAD,Feb 2 2011, 10:57 PM] The 75/140 is over kill in a stock rear 75/110 by Amsoil is what I like and use my self.
Old Feb 2, 2011 | 07:26 PM
TruBluS2k's Avatar
that looks sick
Old Feb 2, 2011 | 08:08 PM
Originally Posted by JFUSION,Feb 2 2011, 10:16 PM
thanks very much for the quick reply, I appreciate your opinion. I was using Amsoil 75w110 last season, when I went to dump it out it seemed to have a buildup of brownish sludge around the drain plug magnet. I wasn't sure if it was just cleaning out old buildup from fluids used by the previous owner or if the Amsoil fluid wasn't holding up. I thought I'd go up to 75w140 and see how it works. I took a used oil sample of the 75w110 and mailed it off to a lab for analysis but the sample got lost in the mail and it never arrived and I didn't have a second sample of that fluid, which really sucks. Is there any downside to running 75w140 on a stock setup ?, since I have it in the diff right now, I might as well make some use of it unless there is a negative to using it. Thanks for any opinion.
No the rear will be fine using it. The 75/140 is for heavy duty use and is just more than you need for your DD S2000. It is a bit more heavy and may hurt the MPG but not by any big deal.
