Sponsored by: CARiD
camber kits
Old May 15, 2014 | 07:03 PM
mrbond413's Avatar
Default camber kits
What is the best way to lower the camber on the front wheels? Right now I'm at stock height, front camber is -.25 and rear is like -1 and that is maxed out. I have all 4 ball joints replaced with spc adjustable ball joints but everytime the shop does an alignment they fight the toe while lowering the camber. I'm getting some adjustable toe arms for the rear but I can't find anything for the front besides adjustable control arms for $600+. I bought some clubsports that should be here in a couple days but I really need to decrease my camber in order for my wheel/tire setup to fit when I lower it.
Old May 15, 2014 | 07:09 PM
sillyboybmxer's Avatar
i was able to get -2.7 out of the front when i was lowered on stock adjustments
Old May 15, 2014 | 07:58 PM
Manga_Spawn's Avatar
Site Moderator
You need to lower it first. Once it is lowered you will be able to dial in more camber.
Old May 16, 2014 | 07:02 AM
mrbond413's Avatar
Thanks for the input
Old May 17, 2014 | 06:29 AM
gptoyz's Avatar
With adjustable sbc balljoints you should definitely be able to get more negative camber.
Is your alignment guy well versed in the setup of double a arm adjustment? Right now you aren't even hitting the limit of the stock components in terms of negative camber and caster.
Can you post up your full alignment specs?
Where are you located?
You may want to consider finding someone who specializes in race car alignment setup for miatas or something if someone is not an s2000 specialist
Sent from my iPhone using Tapatalk
Old May 17, 2014 | 07:28 AM
alphalanos's Avatar
find a race shop. youll pay a little more but they will make sure its perfect, this car needs a good alignment. I just got mine done at a local bmw/porsche shop that works on race cars and they spend a good 1.5 hrs doing my alignment. ended up with -2 front -3 rear, max caster they could get i forget what the toe was but it was a small amount in the rear. i cant go any more positive on front camber because I have Js roll centers and extended ball joint. price actually wasnt much more then a regular tire shop.
Old May 17, 2014 | 05:53 PM
JamesFM's Avatar
I am on lowering springs (no camber kit) and was able to hit -2.25 in front and -3.5 in rear (maxed out).
Here are my specs:
LEFT FRONT
Camber: -2.22
Caster: 6.58
Toe: 0"
RIGHT FRONT
Camber: -2.25
Caster: 6.59
Toe: 0"
LEFT REAR
Camber: -3.46
Toe: 1/16"
RIGHT REAR
Camber: -3.5
Toe: 1/16"
Old May 18, 2014 | 09:57 AM
gptoyz's Avatar
Sweet setup
samson123
Aug 24, 2017 10:19 AM
seansniper
Jan 19, 2012 04:08 PM
Flapjack
Mar 29, 2011 10:42 AM
nigels
May 14, 2010 07:41 AM
TunedS2000
Jan 14, 2005 07:06 AM
