Which rear camber bolts to adjust
Old Jan 19, 2012 | 02:44 PM
seansniper's Avatar
Default Which rear camber bolts to adjust
I have been reading around, and I have found this picture : http://i135.photobucket.com/albums/q...spension2B.jpg
Which of those should I adjust first, or what is the most commonly used one to adjust camber?
Thanks
Old Jan 19, 2012 | 03:00 PM
s2k_05's Avatar
Dont adjust either one. Take it to an alignment shop and have them align it. Both are for camber but they also adjust toe at the same time
Old Jan 19, 2012 | 03:12 PM
seansniper's Avatar
I understand Ill need an alignment, I just want to mess with it and my coils to get a good fit. I will then take it to a shop to adjust the toe.
Old Jan 19, 2012 | 04:08 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Rear of car:
The adjuster on the lower a-arm is for the camber, but it will also have a MAJOR affect on toe.
The round link bar is for toe, but has a MINOR affect on camber.
Trial and error back and forth on both adjustes on the alignment machine is needed to get camber and toe correct.
So if you want to play with it, use the lower a-arm only. But an alignment is a must right away or you will shave the tires. It will also handle unsafely.
samson123
Aug 24, 2017 10:19 AM
irock aypee one
Dec 16, 2006 11:46 AM
hylysly
May 25, 2006 09:10 AM
RazorV3
Nov 14, 2004 08:18 AM
exceltoexcel
May 5, 2004 09:29 AM
