Sponsored by: CARiD
Car vibrates after a spring install
Old May 8, 2008 | 05:45 PM
dnice455's Avatar
Default Car vibrates after a spring install
I have just installed my espelir springs and the car vibrates from the rear when i am accelerating. I was wondering what the problem could be. I have a Ap1.
Thanks
Old May 8, 2008 | 05:55 PM
IntenseImports's Avatar
It sounds like your inner cv joint. It was probably already shot, and when you lowered the car it made it worse. Just swap the driver side with the passenger side, and it should fix your issue.
Old May 8, 2008 | 06:00 PM
dnice455's Avatar
I have heard of driveshaft problems so u dont think thats it?? I am goin to do an alignment once it get settled. Should that help out the problem.
Old May 8, 2008 | 06:07 PM
https://www.s2ki.com/forums/index.php?showt...=0&#entry735569
There ya go!
Old May 11, 2008 | 08:02 PM
waygone79's Avatar
sounds like a dumb idea but set some spacers for the rear axles when you lowered it the rear axles were put in a bind and pulled just slightly (i mean millimeters) there are two in my area who we pulled the rear axles and put in j's racing spacers and it was all good!
Old May 12, 2008 | 08:45 PM
dnice455's Avatar
I was on the Js site and all i seen was drive shaft spacers. Where did you get them from
Old May 12, 2008 | 09:02 PM
FASTSIIK's Avatar
i just went through this myself, with espilar springs also..it is definatly your inboard cv joints. with this you have some options, if you prefer to do it yourself you can just swap your inboard joints from left to right. its actually very easy. or you can just buy some new axles from car stuff
WomenBeShoppin
Aug 25, 2009 05:38 AM
Lopez10
May 17, 2009 08:21 AM
Rain
Jan 25, 2008 05:39 PM
FormerH22a4
May 24, 2006 12:48 PM
Sideways
Aug 9, 2005 05:43 PM
