Sponsored by: CARiD
CEL, EPS, speedometer not working properly
Old Jul 27, 2009 | 08:24 PM
ndk4's Avatar
Default CEL, EPS, speedometer not working properly
I just installed Modifry
Old Jul 27, 2009 | 08:37 PM
CKit's Avatar
Are you sure it's the resonator and not the catalytic converter?
Sounds like you should retrace all your grounds and make sure the connections aren't spotty.
If you're talking about temp on an AP1, you should NOT see anything higher than THREE temp gauge bars. If you're seeing FIVE, you could be frying something. Flush coolant and check for functioning thermostat.
Old Jul 28, 2009 | 06:16 AM
goldenfri's Avatar
Try searching,
https://www.s2ki.com/forums/index.php?showt...&#entry10000838
I just got this same problem with my yellow jacket, and its happened before but it went away on its own. I think it is a flawed product.
Also you should not see more then 3 bars on your ap1 coolant gauge, that could mean serious problems like overheating, which can cause permanent damage. Personally if I saw a 4th bar come on I would turn the car off and pull over asap and figure out whats wrong.
Goofs
Mar 12, 2019 09:05 AM
Fat
Jul 7, 2016 03:15 PM
esafaeian
Jun 6, 2016 04:49 PM
ALBERTS2K
Jan 23, 2016 10:25 AM
Riceball
Oct 14, 2006 11:54 PM
