Sponsored by: CARiD
CF Trunk
Old Mar 3, 2010 | 01:38 PM
S2Kevinn's Avatar
Default CF Trunk
Is the removal of the "trunk springs" necessary for CF trunk installation?
If so, where exactly is the "spring" ?
Old Mar 3, 2010 | 02:29 PM
JPWEraser's Avatar
The real reason to remove the trunk springs from an OEM trunk when installing a CF trunk is simply because the OEM trunk is heavier than the CF trunk (most likely, anyway). With springs installed that are too stuff, the trunk will turn in to a mellon launcher - when the trunk is released, it will fling up much more violently than usual. The trunk springs are located in the top right corner of the picture below, the black rod going left to right in the trunk. It's a torsion spring so it relies on flexing the bar for spring.
Old Mar 3, 2010 | 04:15 PM
HS2K007's Avatar
i had to remove both of mine because it tweaked the trunk upward when it was closed
Old Mar 4, 2010 | 07:07 AM
JPWEraser's Avatar
That too.
Old Mar 4, 2010 | 09:00 AM
speedworksracing's Avatar
Take them off.
My truck got hair line cracks by the mounts because of the springs.
I took the key latch off and used the metal rod from that as a prop rod. Kinda ghetto but it worked.
la_fever323
Feb 8, 2011 06:38 PM
Nathan356
Jan 10, 2011 11:54 AM
s2kev
Sep 12, 2008 01:31 PM
Tony Yeung
May 16, 2005 10:18 PM
