Changing D2S bulbs
Need to swap out my OEM HIDs.
Did a search and couldn't find any detailed instructions on how to replace the bulbs.
Anyone knows of a DIY or a write up for this job?
Thanks in advance.
Thanks in advance.
The easiest way that I've seen is by taking the wheel off, then remove the front wheel well (let it hang or take it off completely).
The other way that I know of involves taking the front bumper off.
I did mine
......... you will need to get a T20 Tamper proof torx bit to remove the cover off the back of the housing.
thats how i did mine and make sure you disconnect the battery befor you start, a shock from a HID ballast will F*** up your day
10000k's look very nice and are still very brite
Thanks for the help.
The rest was easy after taking off the front wheels.
The 6yrs old bulbs are replaced with 5000K Xenon HIDs.
Still very bright compare to the stock 4300K with a blue tint.
Awsome!
Awsome!
Originally Posted by terahertz,Jun 1 2008, 09:57 PM
where did u get the 5000k? i've been looking for some because i thought 6000k was too blue
Bought mine locally in Houston from a good source for $60.
