Sponsored by: CARiD
Cheaper alternative to krank vents?
Old Nov 10, 2010 | 05:30 PM
Moddiction's Avatar
Former Sponsor
Default Cheaper alternative to krank vents?
I have recently had a bunch of smoke coming out of my exhaust at times and thinking it is from oil getting sucked through the PCV. I have heard that krank vents would help this problem.
I don't feel like spending $100+ or whatever it is they go for. I know there are much cheaper alternatives around.
So just looking to see what the best option would be that keeps the costs down.
I think I bought a PCV a good while ago as I had read that was a good way to do it.
Any input on it?
Old Nov 10, 2010 | 05:35 PM
Nick.'s Avatar
hiyo!
https://www.s2ki.com/forums/index.php?showtopic=490389
Old Nov 10, 2010 | 05:43 PM
Moddiction's Avatar
Former Sponsor
Nice thanks man!
Another question now. I have that vacuum line from the valve cover to intake arm blocked off with just a mini breather filter.
So I guess I won't need that part but would that cause any issues then with this system?
Old Nov 10, 2010 | 05:47 PM
SgtB's Avatar
This is how i did mine. Works well. I don't run the front one though, so I don't get any of the vacuum. I hated the sparkplug well noise, and my timing chain cover crank gasket was hissing. I kept the supra valve to help keep boost out.
Old Nov 10, 2010 | 06:09 PM
Moddiction's Avatar
Former Sponsor
Ok sounds good.
If I am getting smoke out my exhaust after a hard highway pull is that most likely from oil getting sucked through the pcv? I am supercharged currently. Never noticed this before a week or two ago.
If that was the issue would the supra pcv block that boost from getting into the crank case and spitting oil into manifold I guess?
Old Nov 10, 2010 | 06:31 PM
Moddiction's Avatar
Former Sponsor
Ok just found a supra PCV I had laying around I got from carquest a year or two ago.
One way i can blow super easily through it. The other way is very hard but seems like a tiny amount of air will go through. Is it normal for a slight amount to go through when blowing on it?
Old Nov 10, 2010 | 06:39 PM
SgtB's Avatar
More than likely it's good. We can't blow even close to 1psi, so your charger will put way more force on the seat and seal it.
I don't know that the stock PCV will fail. I just did it to play around I guess. As far as your smoke, are you sure it's oil? Is it at WOT or once you lift? I know some of those kits run rich up top and that blows black puffs that go away quickly. Of course if it's bluish you know it's oil. Have you done a compression check lately? If you have a low cylinder, drop some oil in it and see if it seals.
Old Nov 10, 2010 | 06:45 PM
Moddiction's Avatar
Former Sponsor
I am pretty sure it is oil. It seems to happen after going wot and then slowing down and then tapping the gas from a stop. Goes away after the first couple steps on the gas afterwards. I did a compression test recently but not since I saw a little bit of oil.
Did it a few thousand miles ago and was 230 across the board.
I am def NOT running rich wot. Wish I was lol. Running a little lean. Like high 12's but only running 7 psi vortech.
Old Nov 10, 2010 | 07:03 PM
s2k aok's Avatar
f-the crank vents, i just got the ones from toyota, they're a lot cheaper...
Old Nov 10, 2010 | 10:37 PM
wisdom's Avatar
Why not vent the the PCV and front breather to the bottom of the car?
